Results 1 to 10 of 11
Thread: Smooth as Silk!
    15,811
    Smooth as Silk!
    OK, I got the correct wheels from Oneway (thanks Peter Moore for the great service! ) and I balanced them, and trued them up, and man alive....................... does it make a difference!
    Man, how nice it is!!
    One happy camper here, and I think this is a BIG money saver, as I grind way less steel off my tools.
    Big relief, as I was a bit worried I'd made a bad purchase with this WC 8" grinder, well, with the balancing kit, and the quality Oneway wheels, boy does it work well!!
    Whoo-Hoo!!
    Goodland, Kansas
    4,834
    Glad to see it is working well for you Stu. I must have been lucky when I got my grinder from Woodcraft. I put a set of Norton wheels on it, trued them up and it is as smooth as butter.
    Bernie W.
    15,811
    I think that the Oneway wheels are a lot more dense than the WC ones too.
    For example, with the WC wheels in place, shut off the switch, and it took 28 seconds to come to a stop, with the Oneway wheels and the balancing system, it took 68 seconds
    Same grinder.
    30,225
    Ever since you started stalking about them, I've been eyeing the Oneway balancing kits. I have the same grinder as you, and although it's not jumping across the bench, it's not smooth, either.
    I was already figuring on buying the balancers, but now I may just have to look more at the Oneway wheels, too. (Hoping not to spend that much money, but on the other hand, you only cry once, right?)
    15,811
    The balancers fit into wheels with a 1" dia hole, so the stock WC wheels won't work.
    I think that the Oneway wheels are worth it, and while you are at it, get the wheel dresser, or make one, as half the battle seems to be having the wheels true, as well as balanced, and keeping them true (meaning round).
    I used my again tonight, the difference is night and day, amazing how smoooooooth it is now, and I think I'll save money on tools too, as you really only grind away a tiny bit each time. I think the Oneway wheels will last longer for this reason as well as they sure seem to be better made too.
    I'd spend the money again in a heartbeat!
    30,225
    Thanks for confirming what I thought I'd seen you say earlier about the size of the stock WC wheels. There was still a bit of price difference between white or pink Norton wheels and the Oneway wheels, but from your comments it looks like it might be worth spending the extra bit.
    I've got one of the diamond-encrusted flat bar wheel dressers (looks kind of like a shaving razor), so I think I'm covered there for now.
    30,225
    'Nother question for you Stu...do I need the 5/8" balancing kit or it is the 3/4" kit?
    ...Never mind, I found the answer.
    The balancing kit works very well. It's worth it to read the directions that come with it. You'll see.
    30,225
    Ordered the balancing kit and two Oneway wheels to go with it. (Nearly twice what I paid for the grinder itself.) I'm blaming Stu if I go broke this month.
    15,811
    Oh sure, blame me!!
    You will THANK me when you get it all installed and see how smooth it runs!
    BTW, good review here........
    New Woodworker Review
    <- gives you a good idea of how it works too.
  1. MDF smooth and rough sides?
    By Tony Baideme in forum General Woodworking Q&A
    Last Post: 08-24-2014, 11:13 AM
  2. smooth talking Cajun
    Last Post: 03-15-2011, 06:00 PM
  3. making a silk purse out of ikea furniture....
    Last Post: 11-03-2010, 09:22 PM
  4. super smooth
    By Paul Hubbman in forum Old Iron
    Last Post: 02-10-2009, 10:38 PM
  5. How to get Danish oil smooth
    By Uys van Rooyen in forum Finishing School
    Last Post: 10-02-2008, 01:25 PM
