Results 1 to 7 of 7
Thread: Gearing up
    13,464
    Gearing up
    Last night I decided to play around with a couple of the gear generation programs to see what I could create on the cnc.
    The two I played with were an online version and a software version for windows.
    The online version one is free and pretty nice to use, but only outputs in svg format, so for my needs I'd have to convert each file for use. This was pretty easy to do, though I found I needed to turn off a few options, like the gear guides as they also exported in the .svg file. To convert the .svg file, simply open it in Inkscape and save as an .eps (encapsulated post script) file and it will import into Vectric as a vector drawing file. I do like the way it allows more than 2 gears and the fact you can add and rpm and see the affects on the other gears.
    http://geargenerator.com/
    The other software version I played with was the one from Wood Gears (http://woodgears.ca/gear/) which had quite a few more gear varieties to play with, including a rack/pinion style. It has built in functions to export to .dxf and Sketchup, as well as several other image/data formats. After playing around with the free version for a while, I decided to pay the $26 for the program. It didn't have a feature to show the rpm, or what I'd rather see is the ratio in relation to the two gears, but may put in a feature request to see if he'll add that.
    So this morning I spent a little time cutting out a couple of samples using a 1/8" end mill on some baltic birch. Here are the results:
Name:	2015-09-29 11.57.23.jpg
    After breaking the tabs and filing them down flush I screwed the gears to my spoil board for a quick test. I had the little gear a little tight and it shows in the video below.
Name:	2015-09-29 12.06.04.jpg
    13,364
    Very cool.
    Now I want to know what you are going to make with it!
    4,701
    However I'm officially at this point.
    Cool Darren, just a note on spacing the gears I was always taught the the teeth on one gear should not bottom out in the other gear it looks like yours could be move a slight amount.
    Thomasville, GA
    6,000
    Very cool.
    Well.....ya got your basic clock.
    Bill Arnold
    East Freeetown, Massachusetts
    3,022
    Very cool.
    Why did the mountain get climbed? Because it was there!!!
    Why did Darren make the gear - because he could!!!
    12,264
    Way too cool color me greeeen then purple with envy.
  1. Gearing Up
    Last Post: 02-19-2015, 03:10 PM
  2. gearing up for the real production run....
    By Dan Noren in forum General Woodworking Q&A
    Last Post: 09-26-2009, 04:14 PM
Tags for this Thread
