Results 1 to 10 of 14
Thread: Round Mortise with Square Tenon?
    I see folks cutting mortise holes with routers. This leaves a nice rectangle with round edges. Then they cut rectangular tenons with square shoulders to go in the mortise. I don't really understand this. Is this a strong join? Perhaps I just watch too many youtube videos?
    Many Thanks!
    5,172
    Router mortises are unfailingly perfectly perpendicular and perfectly sized. Tenons with square corners are easier to mill. The conundrum is to square the corners of the mortise or round the corners of the tenon. For me, it is tons easier (and faster) to pare the square corners round than to mess up the geometry of the mortises. A sharp chisel and learning some simple body mechanics in using it and bob's yer uncle.
    Thomasville, GA
    5,998
    My choice has been to go the route of loose tenon joinery. There are several advantages to this process. Basically, you make the mortises with a router and get rounded ends. After making tenon stock to proper thickness, round over the edges to match the mortise.
    Bill Arnold
    5,172
    Also a good approach. Certainly easy peasy.
    Thomasville, GA
    5,998
    Especially for us lazy types!
    Bill Arnold
    Okay, I read up on loose tenon joinery and it seems like a good place for me to start. Got a couple of questions.
    To "round over the tenon" am I passing the cut to size tenon stock over a round over bit on four sides?
    Uh Oh math may be required here, If I have 1/2" thick tenon stock to go into a 1/2" mortise I would use a 1/4" radius round over bit?
    Thank you all for your patience!
    Thomasville, GA
    5,998
    Yep, your math is right. For a 1/2" tenon, you need a 1/4" round over on each edge.
    Bill Arnold
    Quote Originally Posted by Bob Beasley View Post
    ...If I have 1/2" thick tenon stock to go into a 1/2" mortise I would use a 1/4" radius round over bit?...
    Yessir, I believe that's correct. I'm sure others will correct me if I'm wrong.
    Is there a recommended ratio of thickness of wood to thickness of mortise? For example if I had a 1" thick piece of wood would I cut a 1/2" mortise, leaving 1/4" top and bottom of the mortise?
    Same question for length of mortise relative to width of joining wood? Seems like this would be very important when doing loose Tenoning.
    Feb 2012
    2,749
    I find dowel joints satisfactory. I decided that mortise and tenon joints were too complicated for a computer technician to take on.
    Cheers,
    Roger
  1. Mortise Tenon ?
    Last Post: 08-23-2011, 01:42 AM
  2. 114 Mortise & tenon joints
    By Jim DeLaney in forum Flatwork Project Showcase
    Last Post: 04-14-2010, 10:48 PM
  3. Square and Round too......
    Last Post: 02-24-2010, 02:15 AM
  4. Three Quick Mortise and Tenon Questions
    By Chris Marlor in forum General Woodworking Q&A
    Last Post: 05-25-2009, 03:47 PM
  5. Mortise and tenon Q's... Workbench base
    By Brent Grooms in forum General Woodworking Q&A
    Last Post: 01-13-2007, 06:14 PM
