Results 1 to 10 of 13
Thread: Need Some Good Advise
    Question Need Some Good Advise
    I just finished a deck off my pool and I have to move my hot tub from my old deck to the new......"Its very heavy" Any ideas the best way to do this Any help or suggestions are welcome as I plan to attempt this,
    this weakend.
    15,815
    Joe, lots of ways to do this, but not knowing the environment, it is hard to give advice.
    I will say this, you can move the world with a simple lever and fulcrum.
    The first muscle you should use, when moving heavy stuff, is your brain, which you are doing by asking us!
    If you can give a better description of the move, or take a pic, it would help.
    15,815
    Here is some inspiration.........
    Building Stonehenge - This Man can Move Anything
    I'm trying to send a small sketch of the two locations to better explane the different locations....I hope it works!!!!
    OK I can't seem to get the doc. file below 20kb and max I can upload is 19.5
    ......HELP........
    11,901
    Without seeing your situation, my first thought was: What is more valuable to you, your back or your checking account balance? Meaning, the answer might be to call a professional with equipment.
    15,815
    Joe, can you send another format?
    same level? up-hill or down? 4 feet or 400? wood skirted fiberglass or tile-n-concrete? what are you dealing with?
    Southern Georgia
    1,396
    Joe,
    You may want to contact a local spa dealer in your area. When we had our spa delivered/installed, they had a really neat gizmo that made the job REALLY EASY!
    They had a 'dolly' of sorts that they tipped the spa up onto. There were a pair of wheels at either end that pivoted under the control of the person at each end holding onto a steering rod.
    The installers were able to bring our large spa (850 pounds empty) across a very bumpy yard, around a pool and through a garden. Then, with just the two of them, they were able to bring it up the stairs on the front of the deck:
    I don't know where you're located, but for reference, the standard delivery charge here is "about $100".
    To me, that would be money well spent, since the pro's have the equipment and knowledge to do it right. And it's their back doing the work.
    Just my .02...
    - Marty -
    Fivebraids, Inc.
    When you earnestly believe you can compensate for a lack of skill by doubling your efforts, there’s no end to what you can’t do…
    Punta Gorda, Florida
    902
    The guys that delivered ours a few weeks ago placed it on a length of old solar panel with a rope through it. One pulled and the other one pushed. I was amazed at how well it worked. Off the driveway, over the grass, over some rocks and onto the patio.
    tub is wood surround fiberglass aprox 8-900 lbs ...The move is on the same level aprox 35' away from its current location.
    I appreciate all the replys and will look into the possibility and cost for the spa dealer moving it.......Thanks again for all your great advise.
  1. Tabletop advise
    By Mark E Smith in forum General Woodworking Q&A
    Last Post: 11-05-2014, 08:26 PM
  2. advise?
    By Stephen Bellinger in forum General Woodturning Q&A
    Last Post: 04-09-2012, 12:50 PM
  3. Need advise on drum sander
    By Dave Gallaher in forum New Tools
    Last Post: 10-05-2010, 10:26 PM
  4. need help advise
    By Stephen Bellinger in forum Finishing School
    Last Post: 08-21-2010, 06:43 PM
  5. Advise and help needed
    By Rob Keeble in forum General Woodturning Q&A
    Last Post: 03-02-2010, 04:10 AM
