all I know about CBN wheels and a little more! Need I say (long)?
OK. Wassa CBN?
BTW I use concrete nails for occasional projects. They are very tough and hard. Can be cut with a hacksaw but are hard on blades.
Frank,
All of the answers you have gotten are accurate. CBN is a very little softer than diamond. Diamond is better for sharpening some things, CBN sharpens other things like our particle metal tools better. The CBN is electroplated onto a steel or aluminum wheel and will cut some things that will destroy a diamond wheel. A sleepless night and I forget the "what" and "why" at the moment. The wheels are very long lasting, stay the same size, and run very cool compared to a standard aluminum oxide type wheel. In addition, the grit wheels are sometimes said to just tear out the hardest particles in some of the particle steels like Doug Thompson uses leaving the very edge of your tool only the softer metal the particles are imbedded in so while the bonded grit wheels get the tool just as sharp, the edge of your tool is soft metal. I am buying the particle steel tools when I can so going to CBN wheels from somebody is a must if the claims of the softer wheels not cutting the small particles, only tearing them out, are true.
The wheels have been made in Europe and very pricey. Small specialty wheels like wheels to sharpen chainsaw chains can run three or four hundred dollars and eight inch grinder wheels were in the same neighborhood. The chinese wheels have flooded the market and crashed the price with a handful of people starting to supply the wheels. With the wheels coming from china and some competition you can get wheels as cheap as $130. So far almost everyone has been very pleased with the chinese wheels, one instance where we don't seem to be getting junk. Not fond of buying chinese but I am buying wheels I can't get elsewhere for about half the price of similar wheels from Austria. The wheels from Austria are steel wheels with the CBN bonded to them and I doubt any of my grinders can spin two steel wheels anyway. Because of material and design my aluminum wheels probably weigh about half what a pair of the steel wheels would weigh.
CBN is the fad thing at the moment as are the particle steel tools. However CBN has been around many years, just not in widespread usage. It has stood the test of time in some very demanding environments, production lines. Pretty sure it is here to stay for sharpening harder metals. It loads up badly sharpening mild steel or grinding aluminum or other soft metals. It can be cleaned but best to use grit wheels for some purposes still. The CBN doesn't completely replace other wheels.
As already mentioned in this thread, fine grit CBN grinder wheels are pretty new on the market. I stuck my neck out a bit buying the 220 and 350 grit wheels since the common wheels are 80 and 180 grit. Electroplated CBN cuts faster and perhaps smoother than the bonded grit wheels so the grits can't be compared exactly, an 80 grit CBN wheel doesn't perform exactly the same as an 80 grit stone wheel as an example.
A final thing, because the CBN wheels are finely machined and then a thin coating of grit put on the working surface they come trued and balanced. While they can be dressed they rarely or never need it and usually can just be dropped onto a grinder. I didn't price them elsewhere but purchased a set of the spherical self aligning washers that serve the same purpose as backing plates on a stone wheel when I bought the CBN wheels. All in the same shipping price so I figured I wouldn't beat the real cost to my door elsewhere even if I found them cheaper.
All I know about CBN and a little bit more! I'll soon know more than most about the fine grit wheels. That part is a $300 gamble. I bought the entire line of Starbond CA glues about a year ago to test for myself too. Mostly they have sat unused in my refrigerator. I realized how little I like using CA glue after I bought all of that. Their new KEG glues that are supposed to be four times stronger are nice to work with fresh out of the icebox. Once warmed to room temperature I danged near needed supplied air to use the one I tried. Eyes, nose, and throat burning, strong odor! The odorless CA glue uses a different hardener and is what I will probably use in the future when I have to use CA glue.
Hu
