Results 1 to 10 of 16
Thread: How do you have your electronics organized?
    13,360
    Anyone care to share how they have the power supplies and controllers organized, as well as how you have your cables routed?
    I've got 2 power supplies, and a control board I need to organize. I think I have some ideas for how to route all the cables.
    but just wanted to get any ideas.
    East Freeetown, Massachusetts
    3,019
    I've been through a few variations. From kaos to a little less kaos.
    I do use wire ties.
    I just built a couple of enclosures recently, in an attempt to get things out of the dust.
    I'll get a pic or two sometime today.
    Thomasville, GA
    5,992
    Since I built my SO2 on a shelf, I built a plywood box to hold the electronics on the wall above my machine. My four power supplies are mounted on a shelf under the cnc.
ID:	92827Click image for larger version.
ID:	92828Click image for larger version.
    Bill Arnold
    5,172
    Mine will be in metal enclosures (included in my kits). The metal enclosures will be installed in one end of my base cabinet. All wiring will be in the echains, wire wrap, etc.
    This might help: http://www.allelectronics.com/make-a...devices/2.html
    Sacramento, CA
    1,367
    Here's a slideshow of the box I built for mine... it also shows some of the other cabling solutions like out at the steppers and maybe some of the cable chain (i forget if that's in there)
    The one after this one also has some wiring content in it, too.
    Jason Beam
    Sacramento, CA
    Dec 2008
    falcon heights, minnesota
    5,609
    mine is wired pretty much according to the instructions that came with the shapeoko 2. but the power supply is on it's own shelf, the spindle speed controller is tucked under the laptop shelf, and the arduino is attached to one of the rail ends per the instructions.
    benedictione omnes bene
    www.burroviejowoodworking.com
    12,251
    Well Brent you said it in your Ox post. I think insufficient attention is paid to the aspect of shielding in all these units and wiring layout. Crosstalk and interference is real and can easily be attended to.
    There are valid reasons why emi shielding is used all over the place in electronics. Good grounding is essential consideration too. Dont want to have ground loops. I like Carols point about metal enclosures.
    13,360
    I ordered the shielded wires for the steppers, and also ordered up some shielded wire to use for the limit switches. I figure I might as well just plan on using them while I'm at it. Might be a little overkill, but I figure why not add them now while I'm putting it together.
    Sacramento, CA
    1,367
    I shielded all mine, too - can't possibly hurt and it's cheap insurance.
    Jason Beam
    Sacramento, CA
    13,443
    I've got shielded cables, but since I built mine about 10 years ago, the cable chains weren't all that available and were pricey for the ones that were. The cables are simple held on with cable clamps with some necessary slack as needed. The Laser controller is the most recent addition and it currently riding on top of the carriage.
Name:	2015-10-12 19.35.12.jpg
    The controller is in the original box I built for it, but the power supply I bough a couple years back sits on the shelf in the elements. Power is routed through a main switch on the front of the shelf. I have a SSR mounted inside the electrical boxes on the left side with a kill switch and power plug on the front to control the spindle. None of it is pretty, but all works.
Name:	2015-10-12 19.35.31.jpg
    Currently the PC is on a small computer desk in front of the cnc (sorry missed that pic), but the monitor is wall mounted.
Name:	2015-10-12 19.35.41.jpg
    I am planning to move the CPU inside the office to help keep the dust down on it and do away with the desk. I also am planning an update to move the electronics in a cabinet and add a 4th axis, so look for an upcoming thread soon.
  1. Have you used TigerDirect for electronics?
    By Ron Jones in forum Off Topic Discussion
    Last Post: 05-11-2010, 02:48 AM
  2. Medical electronics has sure come a long ways....!
    By Ken Fitzgerald in forum Off Topic Discussion
    Last Post: 02-19-2010, 04:47 AM
  3. chisel box, re-organized
    By ken werner in forum Neander Tool Questions and Show & Tell
    Last Post: 04-12-2009, 01:40 PM
  4. Silly Poll: how organized are you?
    By Art Mulder in forum General Woodworking Q&A
    Last Post: 02-08-2008, 03:37 AM
  5. Getting a bit more organized.......
    Last Post: 03-12-2007, 11:14 PM
