Results 1 to 8 of 8
Thread: Dang Defective Tape Measure and Yard Stick!
    13,357
    Got a brand new "Yard" stick and tape measure and the put the numbers on them all wrong!!!!!
    Sheesh, What are you gonna do.
    4,552
    I am finding the more I use metric the better I like it
    A Turn N Time
    Frog Pond Guitars
    East Freeetown, Massachusetts
    3,019
    I wonder what is the spacing on center between studs is in metric.
    LOVE seeing the nice 10 - 20 - 30 - 40 - 50........ THAT is so easy to work with.
    Thomasville, GA
    5,992
    Metric is good. I find myself working in metric more and more since venturing into the CNC world.
    Bill Arnold
    13,357
    Do you know how hard it is to find a decent meter stick and metric tape measure in this country?
    Not super happy with the meter stick, but it should do.
    As I've been working with the laser, for some reason I was just doing everything in mm. Thought maybe I'd try to start doing some projects in mm and get a feel for how metric stuff works. Plus my CNC is 1000mmx750mm.
    S E Washington State
    3,777
    Didn't like metric until I built the organ. Now I prefer it.
    "We the People ......"
    Independence, Kentucky
    1,354
    LeeValley has them, A bit pricey though
    Feb 2012
    2,746
    I use imperial for most carpentry work, as that's still the standard for lumber in Canada. It wouldn't be difficult to adjust the nominal sizes of lumber to metric, but it gets more difficult with sheet goods. A 4' wide sheet is nominally 120cm wide, but it is actually 121.9 cm, which is a difference of about 3/4". This doesn't matter if you are doing new construction, but if you are replacing imperial sheet goods, it may give you a problem in spacing. Are there any Brits around who could tell us if they've made this change in Britain? Or Oz or NZ?
    I do use metric if I want to know how much to cut off the end of a stick to make it fit. That way I don't have to mess with 16ths and 8ths of an inch.
    Cheers,
    Roger
  1. My Vintage Tape Measure (circa 1975)
    By Scott R Smith in forum Old Iron
    Last Post: 03-25-2014, 01:35 PM
  2. Measure twice....
    By Rich Soby in forum Off Topic Discussion
    Last Post: 06-12-2013, 11:03 PM
  3. Tape Measure Redesign
    By Rich Aldrich in forum General Woodworking Q&A
    Last Post: 03-22-2009, 11:17 PM
  4. Fat Max Tape Measure
    By Travis Johnson in forum General Woodworking Q&A
    Last Post: 12-21-2007, 11:27 AM
  5. Found a Tape Measure I Can Use
    Last Post: 06-15-2007, 01:41 PM
