Results 1 to 10 of 19
Thread: Dust Boot Addition
    13,437
    Dust Boot Addition
    For the longest time I"ve wanted to get a dust boot on my cnc, but since I need it to be removable for swapping bits, I had a hard time figure out a way to make that happen. Well with the recent addition of the weaver scope rail for adding on the laser, I got an idea.
    So a week or so ago I ordered some brush strips off ebay, in 1" , 2" , and 3" sizes. The strips are 3/16" wide at the metal banding that holds the strips. I wanted to do a friction fit into the boots plate. So here is the design I came up with.
    Using my HF Ring roller I rolled the strip brush to match the radius' of the plate
Name:	2015-10-17 11.27.05.jpg
ID:	92920 Click image for larger version.
Name:	2015-10-17 11.26.57.jpg
ID:	92919 Click image for larger version.
Name:	2015-10-17 11.32.07.jpg
    Next I milled out the plate, all done with a 1/8" end mill, however I think I mis-measured the straight areas.
Name:	2015-10-17 12.02.32.jpg
    No problem, I just cut the straight areas out and re-used the curved parts
Name:	2015-10-17 12.07.23.jpg
    Well, the first attempt, the exact 3/16" groove was a bit tight and blew out the mdf, so remilled a new plate with a little larger groove for it, also thickened the outer wall and made the vacuum hose hole a little larger (which was needed).
Name:	2015-10-17 12.19.47.jpg
    Using a straight screwdriver and hammer I tapped the brush into the groove, was a snug fit, but didn't split this time
Name:	2015-10-17 13.03.26.jpg
    Next I added a support with the scope mount. I used three 3" screws to fasten the support and give it rigidity.
Name:	2015-10-17 13.31.37.jpg
    Lastly, I connected up to my DC.
Name:	2015-10-17 13.34.04.jpg
    13,437
    So a quick test showed no movement in the mount, it seems very rigid. I did have to switch it back to my shop vac as the DC is overheating the relay I have in use to toggle it on/off.
    And the best part is, not one chip on the table after it finished.
Name:	2015-10-17 15.33.45.jpg
    Sacramento, CA
    1,367
    Nicely done!!
    The ability to reach your collet with these things is paramount. Great solution! Legacy uses a ring with RE magnets around 'em and it just snaps into place -- i though that was clever, too.
    Jason Beam
    Sacramento, CA
    13,437
    Quote Originally Posted by Jason Beam View Post
    Nicely done!!
    I've had some magnets on order, but since I use a rotozip, the shaft doesn't protrude as far as some other routers. I'm going to route out another base and use the 1" strips on it. With the weaver rail I can adjust the boot up and down as needed, so those two should fit my needs.
    12,247
    Brilliant...well done
    East Freeetown, Massachusetts
    3,019
    This is something I need to do.
    I like something I can see through and with magnetics.
    I have a pile of hard drive magnets that I will use.
    13,357
    Very nicely done Darren!
    13,437
    One thing I thought I'd mention, is how much quieter things run with the boot in place, especially when I can walk away and go get some work done in the office while it runs. Actually the spindle noise and the vacuum noise was muffled quite a bit by the dust boot.
    13,357
    How long of a cable are you using to run it from your computer? I'm assuming the computer is in the office and the CNC is in the shop?
    13,437
    CNC is just outside the office, but it's on it's own computer in the shop. I do plan to move that computer into the office, but will still be able to get by with a 6' cable.
  1. Dust Boot Update
    By Brent Dowell in forum New Systems and Builds
    Last Post: 11-15-2015, 07:58 PM
  2. Workbench Addition
    By Matt Fornes in forum New Tools
    Last Post: 02-21-2011, 02:07 PM
  3. New addition..............
    Last Post: 01-07-2010, 01:37 AM
  4. a little addition to my case
    By jim capozzi in forum Neander Tool Questions and Show & Tell
    Last Post: 01-27-2008, 09:27 PM
  5. Pictures of my New Addition
    By Travis Johnson in forum Shop Tours
    Last Post: 07-29-2007, 11:32 AM
