Results 1 to 8 of 8
Thread: Dust Deputy - Mounting Hole Patterns
    13,448
    I picked up my Dust Deputy from Ace today, got it home and found a bucket to use, and measured up the hole patterns.
Name:	2015-11-07 16.45.02.jpg
ID:	93245 Click image for larger version.
Name:	2015-11-07 16.57.45.jpg
    I went with a center 3 1/6" hole for the center, and six 5/16" holes centered on a 4 5/16" pattern. Did a quick drawing in vcarve, screwed the lid down in the center and zeroed out on top of the screw head (not really, just really close to it).
    Still need to decide how I want to make it mobile, either on a cart for both it and the shop vac or by itself.
    Attached are the vcarve and gcode files. I used a center datum (starting point), with a 1/4" depth of cut in two passes with an 1/8" two flute end mill.
    DustDeputyMountHoles.crv
    DustDeputyMountHoles_.125_endmill_center_datum.txt
    13,361
    I love it! With my current one, I just used a hole saw and a drill, but now I can really put my CNC to use!
    13,361
    Thinking more about it, what I might actually do is use it to cut an MDF lid for a bucket. The plastic lids are a little flimsy, and difficult to remove.
    Having an MDF lid that would fit tight to the top of the bucket with the DD on top would be pretty ideal.
    13,448
    Cool! Mind posting back your cut files?
    Sent from my SM-G920P using Tapatalk
    13,361
    Once I get it done, I'd be happy too.
    I might go head and make one to retrofit my current dd. Anything that makes it easier to empty the bucket would be nice.
    The more I think about it, the more I think I might make a mobile base for the CNC with builtin DC using the DD and drawers for storage.
    13,448
    I like that idea, should think about that with mine to put the pc and some drawers for bits on the cart.
    13,448
    And so the saved vcarve file came in quite handy...for DD #2!
Name:	2016-05-31 19.54.46.jpg
ID:	96053 Click image for larger version.
Name:	2016-05-31 19.54.59.jpg
    The second one will be on a 2 1/2 gallon bucket for the blast cabinet.
    12,256
    Brent on a sandblasting cabinet video on you tube a guy cut the mdf for fitting inside the bucket given the suction tends to try pull the lid in. So consider adding it underneath on the inside of the lid.
    Darren thats an excellent idea cutting it on the cnc.
    Going to have to get second dd too.
  1. Dust Deputy vs. HF Dust Collector
    Last Post: 06-29-2015, 01:54 PM
  2. New dust deputy
    Last Post: 12-12-2011, 10:49 PM
  3. Dust Deputy
    Last Post: 08-07-2011, 01:17 PM
  4. DIY Dust Deputy® for only $39.00
    By Rennie Heuer in forum Hot Deals
    Last Post: 03-22-2011, 10:15 AM
  5. Dust Deputy Performance
    By Brent Dowell in forum General Woodworking Q&A
    Last Post: 12-31-2009, 07:34 PM
