Results 1 to 7 of 7
Thread: Grizzly TS Insert
    13,437
    Grizzly TS Insert
    As mentioned on my Delta TS insert thread, I offered to make up some inserts for my coworker's Grizzly 1023 table saw. Note the little nubs next to the set screws. These are for him to file/sand down for a tighter fit. I may end up adding some to both sides and the front to allow for a more custom fit.
Name:	2015-11-08 16.20.45.jpg
ID:	93263Click image for larger version.
Name:	2015-11-08 16.32.37.jpg
    I used the band saw to cut off the top half of the nub on the back, this keeps the back of the plate from lifting when the blade is in contact with it.
Name:	2015-11-08 16.40.40.jpg
    Thomasville, GA
    5,992
    Looks good, Darren. You did something I'll have to add to my layout for my Grizzly 691. I hadn't thought about the tab at the rear of the insert, but I think I'll try to set it up for cutting on my CNC. Also, I use 1/2" MDF for my inserts but I leave it solid - no cutout like you did in the blade area - but might revisit that as well.
    Bill Arnold
    13,437
    Thanks Bill. I'm routing the bottom side only, so flipping the work to cut out the space for that nub on the back just isn't worth it, takes a couple of seconds on the band saw.
    Southeast Pa
    2,019
    Great thinking Daren. Leaving the nubs for fine fitting is priceless.
    Garry
    Thomasville, GA
    5,992
    Makes good sense!
    I've been cutting mine from the top since I leave it full thickness. I cut the slot for the riving knife on the CNC but do the blade cut on the table saw so I have a perfect match. I cut the whole insert using a 1/8" two flute bit.
    Bill Arnold
    East Freeetown, Massachusetts
    3,017
    Looks great.
    A couple of years ago I made some band saw inserts to replace the plastic one I melted.
    Lots of great things to use CNC for
    11,825
    Agree. Making your own is simple with a band saw. Getting right thickness is most important part of the project. Without having a planer it could be difficult. But, with, eezzy peezy.
  1. Zero Clearance insert
    By Rob Keeble in forum Jigs and Fixtures
    Last Post: 09-28-2015, 03:26 PM
  2. Grizzly lathe G0698 discontinued vs New Grizzly lathe G0733 Both 18"x 47"
    By Bart Leetch in forum General Woodturning Q&A
    Last Post: 12-29-2011, 03:23 AM
  3. Grizzly Spiral Head Jointer Insert Rotation - G0490X
    Last Post: 11-10-2011, 11:08 PM
  4. closet insert
    Last Post: 07-12-2010, 12:38 AM
  5. table saw insert
    By edward alexander in forum Jigs and Fixtures
    Last Post: 05-11-2009, 01:18 PM
