Results 1 to 8 of 8
Thread: Mortise Jig
    Sep 2015
    Central valley, calif.
    112
    Mortise Jig
    Here's a router based mortise jig I made from info on the great www. I did a search on this site and didn't find anything like it, so thought I would post it. I Like the way it works, and being shop made it's cheap.
    The jig clamps to your bench, the work clamps to the jig, and router is guided by an edge guide running in a track, heres and over all pic.
    The work clamps to the face of the jig. I am using shop made clamps. This jig is good for table leg mortises that are not necessarily centered. Mount the one leg from left side, and to cut the opposing mortise in the adjacent leg, mount it from the right side, no adjustment of the router is required, you do to need change the stops. There is a registration pencil line in the center just align the end of the work to it
    .Click image for larger version.
    The router is guided by an edge guide running in a track and the length of the mortise is controlled by stops in a T track.
    You only need to mark the the center of the mortise and the beginning and end. Then adjust the edge guide to center the bit on the line and adjust the stops to align the start and stop points. Mount the end of the work aligned with the registration mark on the jig body. Repeated mortises can be be cut without further marking or adjustment.
    The main 3x3 needs to be square, thats the only critical part. Except for the T track it is all scrap wood, including the 3x3 that is glued up from 3/4 popular. I have cut 1 1/2 in. table legs and 3 in. bed posts with it. It does work really nice.
    Bill
    Yorktown, Virginia
    5,002
    That's pretty nifty, Bill. I have a need for something like this to cut some long mortises in a bedpost. Thanks for sharing.
    10,600
    I could of used this last weekend. I'm making a bed for a grand daughter.
    Nice job. It looks well thought out and pretty easy to make
    Very cool bill. Thanks for that.
    May 2010
    Orland Park, Illinois, USA
    278
    Bill, great job on the jig. I believe the basics came from Jeff Miller's jig described in Fine Woodworking #172, pp. 69 October 1 2004, and modified by adding the t-track and stop blocks.
    30,002
    Looks like a very handy addition to the arsenal, Bill. Thanks for posting the pics.
    Sep 2015
    112
    Thanks to Robert for knowing the source for this jig, and giving proper credit. I could not recall the source, only that it was on the internet. This jig does work very well for long mortises. I just completed twin beds and used it for the mortises for the panel in head and foot boards, about 12-14 in. long.
    Bill
    13,427
    Wow, that does look like a handy jig, thanks for sharing!
  1. How I Use the Mortise Pal
    Last Post: 02-03-2015, 01:20 AM
  2. mortise techniques
    By Mark Kosmowski in forum General Woodworking Q&A
    Last Post: 07-03-2009, 02:24 PM
  3. Original Mortise Pal - $99
    Last Post: 05-02-2009, 09:44 PM
  4. Mortise Pal and Through-mortises
    Last Post: 09-06-2008, 10:49 PM
  5. $30 off Mortise Pal
    Last Post: 08-30-2008, 01:09 AM
