Problem finding a part for Delta 18 x 36 Drum Sander
Gayl Beals
Muskegon,Mi.
Clip Spring 406-13-327-0001
I have looked on the internet, but I can not find this part so far. It has been a good flat sander.
I checked also and found this. Delta isn't making it and ereplacements doesn't have it, so sounds like it's retirement time unless you happen to find one in stock somewhere. I didn't have any luck anywhere else, either.
Looks like you're not alone...
This thread:
http://www.sawmillcreek.org/showthread.php?226863-Delta-Drum-Sander-Part-Problem
suggested that maybe the parts from the g0458 might work
https://www.grizzly.com/products/g0458/parts
but looking at the respective manuals I'm pretty sure it would be a major retrofit and not a drop in.
This guy made one (kinda - remanufactured the existing one anyway)
http://community.woodmagazine.com/t...rt-for-a-delta-drum-sander/td-p/407627/page/2
Looks like you ?might? be able to use the same trick this fellow did and just attach it with a machine screw:
http://lumberjocks.com/topics/87929
Past that I think you're into (re)manufacturing a new clip setup somehow.
Good luck and let us know what you end up figuring out!
I have it fixed.I should have done it a little different,but it works just fine. I made some clamps and used JB Weld to hold the clamps in place.DSCN1583.jpg
