Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
Thread: dining room chairs
    Dec 2008
    falcon heights, minnesota
    5,642
    dining room chairs
    well, just because the shop is shut down for the season, doesn't mean i get to stop working on stuff. got the first set of parts for one of the dining room chairs done, along with all six back legs. now i just have to get the other two sets sanded. tonight i started the finishing process, which won't be truly done until the spring. at least i got a start with dying the first set of parts. the next step would be to give it a light sanding to knock down the grain, and 3 coats of shellac, before assembly. come spring, it will be that part, along with the re-engraving of the upper back parts. the parts for the fourth one (which replaces the one given away with the dining table) will be done in the spring as well.
    Attached Thumbnails Attached Thumbnails dining chair finished.JPG   001 first set sanded.jpg   002 first set dyed.jpg
    benedictione omnes bene
    www.burroviejowoodworking.com
    30,136
    If you mentioned it earlier, I forgot...what kind of wood did you use on these? Looks oak-like from here.
    13,619
    Nice, like the looks of the chair, what color is the dye?
    Thomasville, GA
    6,065
    Looks like a good start, Dan. Are these the same chairs you were talking about on this thread?
    Bill Arnold
    Dec 2008
    5,642
    yup, white oak. it's kind of a custom mix of trans tint dyes. sort of a medium brown with a touch of a reddish color. (good thing i mixed up about a half gallon, as i forgot the formula). yup, same ones. i'll have to redo the engraving as i don't like the way the first ones came out.
    Dec 2008
    5,642
    been a while, but i've gotten all of the other chair parts sanded. now i have to hit them with the dye, and when i can get into the shop, remake the upper back parts on the cnc.
    Dec 2008
    5,642
    commenced to cutting the parts from the pile of small off cuts.
    Dec 2008
    5,642
    got more of this one done today. finished cutting all of the parts, and planed the leg parts to thickness, and glued them up.
    Attached Thumbnails Attached Thumbnails 001 parts ready for fabrication.jpg   002 dining chair legs glued and clamped.jpg
    Dec 2008
    5,642
    took the legs out of the clamps. trimmed the back and side spindles to size. then planed the rest of the parts to thickness. tomorrow, clean up the legs, mortises and tenons, and start the cnc work.
    Attached Thumbnails Attached Thumbnails 003 back spindles trimmed to size.jpg   004 side spindles trimmed to size.jpg   005 chair parts planed to thickness.jpg
    Dec 2008
    5,642
    started the cnc work on the top backs of the chairs. worked out pretty good.
    Attached Thumbnails Attached Thumbnails 006 start of cnc work.jpg   007 finished cnc work.jpg
  1. Dining Room Table
    By Robert Horky in forum Flatwork Project Showcase
    Last Post: 04-01-2016, 02:14 AM
  2. Rebuilt our Dining Room Table
    By Charlie Plesums in forum Flatwork Project Showcase
    Last Post: 03-20-2013, 03:16 PM
  3. Repair - Refinishing of six dining room chairs
    By Mike Henderson in forum Flatwork Project Showcase
    Last Post: 02-28-2013, 02:34 AM
  4. Ash/Oak Dining Chairs
    Last Post: 09-12-2010, 11:51 AM
  5. (Re)Finish for dining room table
    By Warren White in forum Finishing School
    Last Post: 08-06-2010, 05:12 PM
