Results 1 to 10 of 27
Thread: Table Saw Chip 'n Dip Board
    Yorktown, Virginia
    5,017
    This one was a little out of my table saw comfort zone, but it turned out to be quite tame and kinda cool. I saw someone selling snack boards out of slab lumber with a built in dish to hold dip, or chips or whatever. I couldn't see trying to balance a long board to spin outboard on the lathe to make the dish and don't have a CNC, so an internet search turned up a variety of methods to use a table saw to make coves, chair seats and even bowls. This method is a combination of some of those. I started with a 2' x 4' piece of cheapo 1/2" Borg plywood, marked the center of an arbitrary (just had to be wider than my slab)16" circle and cut it out using a jig on the band saw. Taped a piece of thin cardboard around the cut out to make up for the width of the kerf and then put the circle back in the piece. Then I centered it over the top dead center of the table saw blade and clamped the outer portion to the table with the blade lowered. Using double sticky tape and a cross piece hold down screwed into the circle, I attached the roughly 1 1/2" thick natural edge cherry slab to the circle upside down and centered where I wanted the dish.
ID:	93456Click image for larger version.
    Then, just like making cove molding (so I'm told) turned the saw on and raised the blade until it touched the bottom of the plywood circle and rotated the captive piece a full turn. Cranked the blade (a flat top grind) up a little bit after each rotation until the cut went through the plywood into the cherry and the dish was about 1 1/4" deep. I shut off the saw and pulled out the piece to check the depth every few turns. The cut was very smooth and didn't take much sanding with a 3" sanding disc to get it smooth. You can tell by the little nub that I was a bit off estimating top dead center, but it wasn't much of a problem to chisel off and sand smooth....just like a bowl bottom.
ID:	93458Click image for larger version.
ID:	93453Click image for larger version.
    Ran both sides through the drum sander, softened all the edges, sanded to 220, slapped on a coat of Doctor's Woodshop Walnut Finishing Oil and voilà! A cool natural edge, avant-garde, neo rustic snack platter for whatever you want to serve up. Both sides of the board are usable and when the walnut oil dries I'll put on a coat of the same walnut oil beeswax paste I use on my salad bowls and buff it to a nice soft luster.
ID:	93451Click image for larger version.
ID:	93459 Click image for larger version.
    Independence, Kentucky
    1,355
    Nice piece Ted
    4,552
    Way Cool Ted
    A Turn N Time
    Frog Pond Guitars
    10,604
    Very interesting I'm thinking Christmas gifts
    13,361
    Very interesting. Make sure to enter it in the http://familywoodworking.org/forums/...-and-give-away thread!
    Quote Originally Posted by Jay Caughron View Post
    Way Cool Ted
    How funny . . . my exact words . Love it.
    13,452
    Neat technique! Will need to try that one
    Sent from my SM-G920P using Tapatalk
    That is very cool, I would use this to make Christmas presents to take home for Christmas this year, but I fear they would fill my luggage rather quickly.
    Jul 2015
    Tahlequah, OK
    272
    Very cool!
    Jul 2007
    DSM, IA
    5,719
    That is very cool!
    My Website
  1. Vertical Chest Board and Chalk Board
    By Jeb Taylor in forum Flatwork Project Showcase
    Last Post: 02-25-2012, 10:56 PM
  2. Board Buddies for the table saw
    By denis gefter in forum General Woodworking Q&A
    Last Post: 04-07-2011, 05:03 PM
  3. Chip Carving
    By gary doby in forum General Woodworking Q&A
    Last Post: 03-31-2009, 01:43 PM
  4. Welcome Chip Charnley!!
    By Stuart Ablett in forum Welcome and Introductions
    Last Post: 11-03-2006, 06:52 PM
