Results 1 to 8 of 8
Thread: Fridge Kiln
    13,464
    Fridge Kiln
    I was watching a woodturner's show on PBS tonight and they were doing bowl blanks. For drying the blanks, the host took them to a feller that was using an old gutted refrigerator as a kiln. He had several plywood shelves with lots of circulation holes in them. At the bottom was a 60 watt light bulb and a small circulation fan. There were also adjustable vent holes, on at the bottom and one at the top. The light bulb was connected to a thermostat and he kept it at about 80* consistently.
    Looked like a good solution for someone that wants to speed up the dry time and has the space.
Name:	2015-12-04 23.14.28.jpg
ID:	93670 Click image for larger version.
Name:	2015-12-04 23.16.18.jpg
    East Freeetown, Massachusetts
    3,022
    It is amazing how inventive people can be with minimal materials to work with. I am impressed.
    I've heard of others doing this to dry roughed-out bowls. Great solution, especially if you have the space and are turning a lot of bowls.
    Yorktown, Virginia
    5,022
    And great for cold smoking salmon too!
    North West Indiana
    6,099
    An old refrigerator with a incandescent light bulb is an excellent place to store your welding rods as they out in the open will draw moisture ruining them. The new fangled lights won't work as they don't put out the heat to keep things dry.
    Jon
    Feb 2012
    2,749
    How much time will this save? I have heard of people putting bowls in the microwave for three minutes to dry them out. I could do that if Marion isn't home.
    Cheers,
    Roger
    13,464
    Ha, maybe not that fast, but sounded like from the video that it would still take a few months, but that's probably a lot faster than waiting a year. The biggest thing was to make things dry consistently, it's the spikes in temp/moisture changes that cause the checking in the blanks.
    Oliver Springs, TN
    1,726
    I built one out of 1/2 inch ply that's about the size of a mini refrigerator. I put a couple of holes in the bottom and a couple at the top for air flow. A light for heat, and computer fan in the bottom to circulate air. I also put a gasket around the door. I have it on a timer and run it 4 hours on and 2 off. I use it to dry pot call blanks, pen blanks, 2x2 stuff, really anything small. It does a really good job. I can dry stuff in a couple of weeks. I can tell when things are getting dry, the temp will go from the low 90's into the 100's.
  1. Unwanted Fridge Snoopers?
    By Dave Richards in forum Off Topic Discussion
    Last Post: 05-21-2014, 06:36 PM
  2. New Sake Fridge Shelves
    By Stuart Ablett in forum Carpentry and Construction
    Last Post: 06-21-2011, 10:24 AM
  3. I Need A New Fridge
    By Pete Jordan in forum Lathe Project Showcase
    Last Post: 07-18-2010, 02:12 PM
  4. Kiln vs. Air Dry
    Last Post: 03-31-2010, 05:30 PM
  5. Veneer press pump from fridge?
    By Mike Heidrick in forum New Tools
    Last Post: 04-16-2008, 03:41 AM
