Results 1 to 6 of 6
Thread: Use the correct blade on your compound miter saw!
    I slapped an old 12 inch blade on my miter saw when sharpening my good one. I used it several days with no issues. Then when trimming a piece of oak about the size of a cigerette pack it, I had the piece flat on the table. The saw was out far enough for the blade to lift the edge of the board closest to me and flip it so it now rested vertically against the fence. My left hand held the piece flat on the table until the board flipped. Then my newly sore finger was pinched between the board and the fence. The board hit the fence so hard it split lengthwise and was thrown clear. My finger was black for 3 days and is still numb. The moral of the story is to use the recommended crosscut blade with a lot of teeth and to cut boards vertically when possible is probably a good idea.
    13,452
    Ouch! Good to hear it wasn't any worse Andy. What is the tooth setup on the old blade? Does it have some kind of hook at the point rather than being flat?
    10,604
    Good lesson for all of us. Glad you are OK
    here is a link on selecting the right blade. according to this article miter saws should have lots of teeth and a negative hook. i seem to recall a negative hook of 0 to -10 degs. http://www.agecuttingtools.com/selecting-sawblades.html
    11,833
    We had a good thread on this subject a couple years ago. A result of that thread, I purchased an Onsrud blade for my CMS. It is made for cms with the proper negative rake. Thus far I am very pleased with it. Of course, I had to learn to not pull the saw through the wood but pull out, lower and push through the piece being cut. This is not an intuitive move for a beginner, I had to be told right from wrong. BTW, Onsrud blades are not real expensive, check them out.
    I had made many straight down cuts with no problem with this blade. It was the first time I had pulled the saw out, down and was begining contact on the push away stroke when it grabbed. I am not sure of the tooth geometry, I will check. I am sure it will be obvious to the experienced that the blade was wrong. To me it looked like a saw blade and the hole was the right size!
  1. Compound Miter
    By Jack Reynolds in forum New Tools
    Last Post: 01-13-2012, 11:35 PM
  2. compound stave miter jig
    By tom daniels in forum Jigs and Fixtures
    Last Post: 12-08-2010, 01:14 AM
  3. new makita compound miter saw
    By Dan Noren in forum New Tools
    Last Post: 10-27-2010, 12:33 AM
  4. sliding compound miter saw fences
    By Carol Reed in forum New Tools
    Last Post: 03-18-2010, 02:46 AM
  5. ZCI on a sliding compound miter saw?
    By Jim O'Dell in forum New Tools
    Last Post: 06-18-2007, 11:48 AM
