Results 1 to 10 of 30
Thread: Clamp Rack
    1,289
    Clamp Rack
    Can anyone tell me a good place to order the Flange Bolts in bulk for this?
    Thanks in advance
    DT
    Last edited by Stuart Ablett; 05-05-2007 at 07:17 AM. Reason: Fixed the link in the picture
    Don, I am not sure what you mean by flange bolts. I would assume something like toilet bolts? Perhaps somewhere like https://reidecom.reidtool.com/xephr/qbe/HOMEPAGE?
    While that system looks nice I think it uses too much wall space. How about something like this??
    This was my solution and it allows me to change brand/type of clamps easily. All it cost me was a few pocket screws and some scrap wood. Its using a french cleat, which I am mounting everything (including my upper cabinets) on to allow me to re-arrange as I need to without a major production.
    17,516
    don keep it simple:)
    i would have to agree with brett, the rack you pictured sure looks nice butthere is alot work and hardware put in to that one that in my opinion is unesacary ,, you could save your time and technique for bigger and better things. i just took and nothced a 2x4 and put some braces under it for support. thats what steveC has to but he used 1" hardwood. so think it over again maybe and you can come up with a simpler design just my opion don,, we know you got lots of ideas tha thave been clever like your set at style bench
    3,147
    Don
    To use space that would go unused behind a door in my small shop I hung F style clamps 4 deep on dowels like the top part of your pic. For pipe clamps & other clamps like bar clamps I just bored holes 1 1/2" in from the edge of a piece of 3/4" plywood & cut slots to the hole then screwed the plywood to s 2x4 & screwed the 2x4 to the wall. I later on purchased some light weight aluminum bar clamps like in your picture & drove headless nails into the 2x between the pipe clamps & drilled holes in the ends of the light weight clamps & hung them on the nails. I ran out of room for the last batch of spring squeeze clamps & found I could just let them grip on between the pipe clamps on the same rack.
    This is an earlier pic there are now many more
    I would encourage you to keep it simple & inexpensive.
    Punta Gorda, Florida
    902
    Don,
    My Ace Hardwares around here will usually sell me stuff like that by the box if I ask and the price per unit is much, much less. I never see them marked by the box so I have to ask.
    I notice that most guys seem to have their clamp racks mounted to the walls and I do also but I do not like it. I have to carry three or four clamps twenty feet or so and make two or three or four trips and then do the reverse when I am done to put them back. It seems to me that it is a waste of time and effort. If I had your uncluttered room I think that I would consider making that rack, or whichever one that you use, into a mobile rack.
    I can tell that you work a lot neater than I do which would help, but I end up piling up clamps all over the floor and pretty soon there is no place to walk without kicking them somewhere else. I think that if I had a mobile rack that I would hang them up when I am finished and keep them out of my way and save a lot time in the process.
    3,147
    Quote Originally Posted by Allen Bookout View Post
    Not at all Allen just think of all the good exorsize your getting. Yes I know I spelled Exorsize wrong but not really Exorsize as in Exorsizing the fat..
    Sacramento, CA
    1,367
    I guess i'm gonna go against the grain and encourage Don with this one. I made the 2x4 blocks and absolutely love this setup. Since my shop's constantly evolving, I'm constantly adding more clamps to the collection. The blocks on t-track makes expanding or rearranging things MUCH easier than making new holders.
    For the bolts, I used regular old bolts, 4" long if i remember right. I picked up a box of 100 from the hardware store. Around here, there's a place called Blue Collar Supply that sells bolts by the pound ... like $3/lb ... i don't buy screws at the hardware store anymore!
    As for the wall space issue, I'm not sure I agree with what's been said. My shop is 8' wide, 23' long with 6'3" ceilings (yeah, short!). After struggling with the notched board style system and a few other ideas, I determined that this system stores more clamps without protruding too far so that the door in front of it can open fully unobstructed. I'm redoing the whole shop now, but i'll take pics when everything's done.
    I have doubled my Bessey collection and rearranged everything so the whole system is due for a bit of a reorganization.
    Jason Beam
    Sacramento, CA
    11,901
    The younger people here need to take note. I looks like being in the clamp selling business would be a sure road to riches. I mean, y'all do have a whole buncha clamps. Mine get hung from joists or piled unceremoniously under the workbench.
    Floydada, Tx
    1,941
    Don call your local plumbing supply house. They will be able to give you are great deal on them. I went thru a local plubming supply house when reran plumbing and saved huge.
    9,110
    I wasn't able to find anything reasonable on bulk T-bolts. There are t-tracks made to accept standard hex head bolts / screws. Maybe this would be an option.
  1. Clamp Rack
    By Jay Caughron in forum Jigs and Fixtures
    Last Post: 09-02-2013, 10:17 PM
  2. Clamp Rack
    By Bob Gibson in forum Jigs and Fixtures
    Last Post: 01-03-2011, 09:58 PM
  3. Rolling Clamp Rack
    By Brent Dowell in forum Jigs and Fixtures
    Last Post: 10-31-2009, 07:27 PM
  4. Another Clamp Rack
    Last Post: 08-12-2007, 12:51 AM
  5. My new clamp rack
    By Jim Hager in forum General Woodworking Q&A
    Last Post: 02-27-2007, 12:38 AM
