Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
Thread: Tap handles - and a cutting question
    4,698
    Working on a pub tap handle design. The final ones will have the lettering blacked in (probably laser cut, no I'm not getting a laser yet), for testing I have been just quickly cutting out the letters with a V chisel to get a feel for how they fill the space.
    I'm using those dreadful brass insert jobbies in the bottom for attaching to the tap (sigh, what the customer wants..), it fits with the design anyway I guess.
    Below is the cut plan. Basically taking a 1"x2"x8" and cutting three bevels on it, one off of either side and then shaving the front back so it tapers away from you.
    I've been currently cutting the square blank, adding the insert (more wood == less likely to crack). Then I cut the two side tapers on the bandsaw and clean them up with a hand plane and finally cut the front-back taper and hand plane it smooth.
    This clearly isn't the most efficient method of cutting this shape out..
    So I'll throw it out to the rest of y'all - how would you cut these out? No idea to crazy.
    East Freeetown, Massachusetts
    3,019
    I think a band saw is probably best. I don't like that on a SCMS - the pieces are just too thin and long. Same with table saw. I would feel good on the band saw.
    On CNC, I would need a jig of some sort and it would be a little cumbersome. Still it would need to be sanded.
    I would walk up to the band saw with that.
    NOW - the text would be CNC. I could get that real easy and it would be real nice. Could even add some
    embelishment there.
    I think the brass inserts are a great idea. I might want to epoxy those in place.
    13,357
    Not a huge fan of the brass inserts. I prefer the tap handle hangers with a ferrule. It just seems to give things a more 'finished' look if you ask me.
    What I would do to cut the tapers would be to have a jig on a sliding crosscut jig. Use a hold down and it should make pretty quick work without a lot of clean up.
    Nov 2012
    Wapakoneta, OH
    611
    Maybe a combination if the ideas above, cut the edge tapers on a taper jig, and the face taper on the BS. Probably cut the edge tapers first (?). It would be interesting to hear how you go about it.
    13,437
    I'd probably go with as the others suggested, maybe use a sled to plane the bandsaw'd edges if you need them to look clean.
    It may be my tablesaw-centric mind but, I would use a taper jig. Cut the wide face first, then do the two sides.
Name:	Taper Tapper.jpg
    10,600
    That's how I would do it as well.
    Yorktown, Virginia
    5,009
    Couldn't you do multiples on a CNC? Set it up so that the outline and taper get cut shy of half way through the board, then flip, index and repeat leaving an eighth of an inch of the outline holding the piece in the center of the wood to saw off on the bandsaw? Seems like you could do many at a time.
    13,437
    Yes, do it on your cnc Ryan! (waiting on the new toy thread now)
    11,825
    Turn on lathe.
  1. Chain Saw Blade Cutting Question
    Last Post: 02-19-2011, 02:30 AM
  2. End grain cutting board oil question
    Last Post: 11-27-2010, 02:53 PM
  3. cutting plexiglas question
    By Frank Fusco in forum New Tools
    Last Post: 10-26-2009, 06:12 PM
  4. Question on cutting aluminum
    Last Post: 02-08-2009, 01:27 AM
  5. Replies: 10
    Last Post: 07-10-2007, 06:37 PM
