Results 1 to 8 of 8
Thread: 3D cutting boards
    Unhappy 3D cutting boards
    Hi if anyone has info. On 3D cutting boards
    With measurements and thicknesses I new to
    This and need as much info as possible. Thanks Vic.
    30,014
    I wrote this quick tutorial years ago. There are no dimensions, because those can vary a lot, depending on the size of board you want and the size of lumber you have available. You can create a mockup with paper pieces cut to size to get an idea of the dimensions you want to use.
    http://workingwoods.com/3-D_Board_Tutorial.htm
    Jul 2007
    DSM, IA
    5,719
    I've seen it before, but thanks for posting your tutorial again Vaughn! Gotta try one of those soon.
    My Website
    30,014
    Just a note...in the photos I show a "60 jig" that has caused confusion with some folks. Measured one way, it's 60...measured another it's 30. At the end of the day I don't think the actual angle matters a lot. It just needs to be consistent.
    Feb 2012
    2,747
    Excellent! I'll have to do that, this year.
    Cheers,
    Roger
    Oliver Springs, TN
    1,726
    I made a couple of boards using Vaughn's tutorial. They turned out great!
    heres a picture of the one im currently working on
    following this writeup
    http://lumberjocks.com/jfk4032/blog/39386
    the blocks arent glued together yet. just lined up sittin on my ts
    Tellico Plains, Tennessee
    4,351
    Thanks for the tutorial, but that thing made me dizzy....
    Chuck
    Tellico Plains, TN
  1. Some Cutting Boards
    By Jeff Bower in forum Flatwork Project Showcase
    Last Post: 11-10-2014, 08:50 PM
  2. Some Cutting Boards
    By Gary McFarlane in forum Flatwork Project Showcase
    Last Post: 10-17-2009, 09:59 AM
  3. cutting boards
    Last Post: 08-06-2009, 06:29 PM
  4. Cutting boards
    By Bobby McCarley in forum Flatwork Project Showcase
    Last Post: 09-30-2007, 06:55 AM
  5. Cutting boards
    By Jim King in forum General Woodworking Q&A
    Last Post: 02-09-2007, 08:20 PM
