Results 1 to 10 of 12
Thread: Bow front lowboy dresser challenges
    Vacaville CA.
    100
    I am pretty new to sketchup but thanks to youtube video tutorials I am catching on. Here is a dresser I am working on. The piece will present some new challenges for me. I have done a few bent laminations and use a vacuum press but haven’t done bent lam drawers before. I am pondering joinery for the drawer face to the drawer box. I suck at hand cut dovetails so looking for alternative methods. Also pondering drawer guides as one drawer side is longer than the other. The rest is pretty straight forward for my skill level.
    Yorktown, Virginia
    5,011
    13,439
    Nice looking design. How about either half blind dovetails using a jig? Or sliding dovetails from the bottom up? Either would probably present a challenge with those curves.
    10,604
    This will be fun to watch
    Thomasville, GA
    5,992
    Since your design has a fairly shallow bow, the inside of the drawer fronts could be flat, allowing half-blind DTs or lock rabbets.
    Bill Arnold
    5,171
    Two issues. One, the corner joinery and, two, the guides. The second is easiest. The draw will only open as far as the shortest side will allow it, so your guides will still be an equal length.
    The corner joinery. If you want to use power machines then you will have to introduce a 90º corner on the inside. A slight bevel cut with the bevel face the width of the thickness of the sides will do. Since fixturing that in a dovetail jog would be problematic, I'd consider a locking rabbet joint done with the table saw and router. Still be tricky holding the drawer front at the right angle, but doable. Traditionally, handcut dovetails. So here is the opportunity to get good at it!
    Vacaville CA.
    100
    Thanks, I tend to lean toward full extension guides to ensure smooth operation. Last thing I need is complaints from my wife that the drawers are hard to open. I like the idea of a drawer box with a curved front then attach the drawer face. For me attaching the faces once the drawers are in place insures the exact spacing and gap I want. I do have a couple different designs for the base or feet I have drawn up.
    SE Minnesota
    2,526
    I like the straight legs better. The last one has some possibilities but I think the bottom rail above the base should be at least as wide as the top rails and the side rails on the base should be as wide as the front rail. The feet in the last one look a little awkward with the stiles at the corners. Maybe if you separate the base from the rest of the case with a panel about 3/4" thick. (Or what looks like a panel anyway.) Since the drawers are flush, I would be inclined to make the panels flush. Maybe with a narrow gap between the panel face and the rails and stiles.
    The feet are lousy on my model but I hope it gets the point across. They should extend up to the bull-nosed trim instead of stopping where I show them, too. I didn't spend much time on this so don't look too closely at the details.
    Vacaville CA.
    100
    Quote Originally Posted by Dave Richards View Post
    I see what you mean. I like what you did with the base, feet and styles. Thanks for taking the time to draw that up.
    SE Minnesota
    2,526
    Happy to help. Show us more of your design ideas.
  1. a bit of excitement in front...
    Last Post: 02-10-2013, 03:56 PM
  2. Finish Challenges in Single Digit Humidity
    By Carol Reed in forum Finishing School
    Last Post: 07-11-2012, 12:57 AM
  3. And the front fell off
    By Drew Watson in forum Off Topic Discussion
    Last Post: 06-25-2010, 01:51 PM
  4. SketchUp Challenges
    Last Post: 05-21-2008, 09:55 AM
  5. The Front Fell Off
    By Dave Richards in forum Off Topic Discussion
    Last Post: 06-08-2007, 01:34 AM
