Results 1 to 2 of 2
Thread: Cutting Thick Aluminum of the lathe
    Oct 2009
    Harrisburg, NC
    140
    Should be On the lathe not Of the lathe
    I have projects in mind to make two 12" sanding disc and one 16" backing plate for a donut chuck.
    The aluminum stock will be 5/8" and 3/8" thick.
    The 3/8" will be mounted to a 6" faceplate and an old 9" sanding plate that I have from an old lathe to make 12" sanding disc.
    The 5/8" will be mounted to a 6" faceplate for the backing of a 16" donut chuck.
    I am thinking of using these type cutters (last in the top row) to cut them almost all the way through on the lathe so that I know they are centered true.
    The final cut will be made with a grinder off of the lathe.
    Would you use a different style cutter bit?
    Any do's and don't? I will wear and faceshield and long welders gloves just in case.
    http://tool.wttool.com/search?p=Q&lb...ew=grid&cnt=48
    All tyranny needs to gain a foothold is for people of good conscience to remain silent. Thomas Jefferson
    Yorktown, Virginia
    5,015
    Those should work. Also consider cutting the circles with a saber saw and truing them up on the lathe.
  1. thick 'n thin puzzlement
    Last Post: 04-16-2010, 09:13 PM
  2. Thick Ash bowl
    By Mark Cothren in forum Lathe Project Showcase
    Last Post: 12-02-2009, 12:56 PM
  3. Question on cutting aluminum
    Last Post: 02-08-2009, 01:27 AM
  4. Forrest WWII Review - GREAT Blade for cutting Aluminum
    By Doug Shepard in forum General Woodworking Q&A
    Last Post: 10-30-2007, 01:00 AM
  5. Replies: 11
    Last Post: 11-26-2006, 04:25 PM
