Results 1 to 10 of 15
Thread: My Frankenstein Mortiser
    Mar 2012
    Hinton Alberta
    52
    Not exactly woodworking but for wood working. I wanted to upgrade my mortiser but spending that much just to drill square holes seemed like a bad investment since it still couldn’t do everything I wanted. I have decided to experiment with my old Delta Shopmaster. The design will allow me to pursue better wagon hubs and a X,Y axis available for fine adjustments with the advantage of raising the working height of the chisel and increasing its working distance. If all goes well I can add specialty tables like tilting applications. I hope to find out soon if I had a good idea or a kick butt boat anchor. I hope everyone is getting shop time and making dust unfortunately, I am not.
    13,436
    That looks like it will be a beast.
    10,600
    4,698
    Looks like it will be a beast! Looking forward to seeing how this goes.
    Mar 2012
    Hinton Alberta
    52
    After some head scratching I thought a universal base would be better for my needs adding a different table for my applications. Moving to a bolt on table gives a wider range of options but each will have to provide a y movement. I had a small issue with slight play in the table in a certain spot and finally found it. I switched to a UHMW slide which allowed a very snug fit on the table slide without any play. Several jack bolts in the head will straighten the chisel to the work regardless of slight imperfections, provided the table stays true without slop while adjusting which I think I caught. Still need a lift system but the weekend is looking open for playing in the shop!
    13,357
    Mar 2012
    Hinton Alberta
    52
    So far so good. Zero play in the table thanks to the UHMW, I cut it very snug and it does translate to effort need to move the table but a trade-off for accuracy I am happy to deal with. As for raising the head I am trying a 1” treaded rod on the back of the unit, with all weight on the front binding may be an issue but we will see. Just button welded as not to distort alignment I will glue it down solid tomorrow and affix slotted supports on the mast to allow for adjustments to square the bit to the work. I have a couple projects started waiting some wheels since last spring but I think a small wooden wheelbarrow will be its first stress test should all go as planned.
    Mar 2012
    Hinton Alberta
    52
    Today was a bust, just got started and ran out of wire for the mig. Picked up a roll and when I got home company was at the house, just got some progress happening and realized I had no 2” inch material left to finish the lift system. Lol tomorrow is another day. I made a new cap for the post as I was going to weld it on but thought if anything happened to the mortiser I would have to do some cutting to remove the mount so it will be bolted on instead. Got a half day at best tomorrow to work on it provide I can scrounge some scrap metal to finish, if not it will be a few days to get back at it. not sure how to rotate the pic but tilting my head seemed to work
    12,247
    Quote Originally Posted by Eric Black View Post
    Nice mortiser build Eric but what are those projects? Soap boxes? Trying to figure out how wheels go on?
    Mar 2012
    Hinton Alberta
    52
    hi Rob they are actually wagon chassis one front view and the other the rear here is a pic from the side on the shelf collecting dust.
Name:	wagon profile.jpg
    not much done on the mortiser today just the pivots top and bottom. mounting the mortiser tomorrow and a handle to crank the head up. Looking forward to the test drive
  1. That Ain't a Mortiser. This is a Mortiser
    By Dave Richards in forum General Woodworking Q&A
    Last Post: 05-15-2014, 12:33 PM
  2. Frankenstein lathe?
    By Al killian in forum Turning Tool Questions and Show & Tell
    Last Post: 12-06-2012, 06:20 AM
  3. Frankenstein Rocker build
    Last Post: 04-08-2012, 02:21 PM
  4. jet mortiser
    Last Post: 02-28-2010, 12:47 AM
  5. Do you own a JET mortiser?
    By Jeff Horton in forum New Tools
    Last Post: 08-11-2008, 11:46 AM
