Results 1 to 10 of 10
Thread: Another great article from Dave Richards
    Dave Richards' article on axes was very informative. This will eliminate a recurring problem of mine in SketchUp.
    http://www.finewoodworking.com/item/...ok-at-the-axes
    May 2010
    Orland Park, Illinois, USA
    278
    Glenn, some great tips in here from Dave, the MASTER of SU. Thanks for letting us know. I already have a model in which to put them to use.
    13,437
    Good article Dave! I need to practice setting those more often, would really help me when I need to make changes to some of the components of a drawing.
    4,698
    Huh, I didn't even know you could do that. Neat
    Thomasville, GA
    5,992
    Good article! I can relate to the angled parts situation. To fix the bounding box orientation, I've been copying the component, exploding it, make it square to the ground plane, restore it as a component, then rotate back to the desired position. Now that I know about using the "Change Axis" operation, that'll be much easier! I've used "Change Axis" in other situations, but not this one.
    Thanks, Dave!!!
    Bill Arnold
    SE Minnesota
    2,524
    Thank you, gentlemen.
    Bill, I'm glad this Change Axis thing will streamline your work. The method you were using is a lot of unneeded work.
    I know of some people who just draw all their parts on axis and then move and rotate them into position. To me that seems like working harder, not smarter. You have to know all of the dimensions of the part to draw it. By drawing the parts in place, you let the parts you've already placed (correctly) determine at least some of the dimensions. With practice it becomes trivial to change the axes to align correctly with the part.
    13,437
    Quote Originally Posted by Dave Richards View Post
    Guilty! And to have to modify them after was a pain too, rotate to the main axis, modify, then rotate back...I'll be using this from now on.
    Thomasville, GA
    5,992
    ... Bill, I'm glad this Change Axis thing will streamline your work. The method you were using is a lot of unneeded work. ...
    I feel kinda dumb now, not thinking to apply the axis change as you show. I've had to changes axes in situations like re-sizing a component where I moved part of it away from the established axes, defining a knob center, etc. Since I'm doing mostly CNC work now using mostly VCarve Desktop, I'm not using SU like I did but I still rely on it for all other drawing.
    Bill Arnold
    13,357
    Dave Never disappoints. I'm guilty as charged as well.....
    Great article!
    SE Minnesota
    2,524
    Well, I didn't mean to make anyone feel guilty or stupid. Sorry about that.
  1. Calling Dave Richards.....Paging Dave Richards......
    By Ken Fitzgerald in forum Designs, Plans and Sketches
    Last Post: 12-06-2012, 06:03 PM
  2. Thank you Dave Richards
    By Alan Bienlein in forum Designs, Plans and Sketches
    Last Post: 12-07-2009, 11:08 AM
  3. Calling Dave Richards! Dave, what's your twenty?
    By Bill Lantry in forum Off Topic Discussion
    Last Post: 07-11-2008, 09:46 PM
  4. Dave Richards, I see you did it again........
    Last Post: 11-17-2007, 01:08 PM
  5. Welcome Dave Richards
    By Vaughn McMillan in forum Welcome and Introductions
    Last Post: 11-23-2006, 04:03 PM
