Results 1 to 4 of 4
Thread: laser bond glue ?
    11,833
    laser bond glue ?
    Anyone here have experience with the laser bond glue that is being advertised on television?
    Supposedly it will not set up until exposed with a special laser light. This could be great in setting two pieces exactly without having the glue bond before you are ready for it. Is is good for wood or too brittle, etc. ?
    What kind of glue is it? I'm guessing a type of CA.
    Sep 2015
    Central valley, calif.
    112
    I did see a commercial for glue that cures with u/v light. The commercial pointed out that dentists use it. I think my dentist used it for some dental work I needed. It looks really strong on tv.
    Bill
    4,699
    Never used it, but as best as I can figure its one of a large number of UV cured plastics. The reviews are all over the board but I read one that basically boiled down to "you don't get a lot fo the price and other products in the same class work just as well or better depending on what you're trying to glue".
    https://en.wikipedia.org/wiki/Light-activated_resin
    Other products in the same space (which ?may? or ?may not? contain the same resin.. how would you know?) are:
    Bondic
    RapidFix UV Liquid Plastic (which appears to come in several classes)
    5 Second Fix
    Bondtastic
    There are likely others... apparently some home stores have various products of this class in the glue aisle now.
    No personal experience, but I once saw a pair of guys installing glass cabinets in a high-end kitchen (not glass doors -- glass cabinets) and they were using a UV-activated glue to connect the pieces together.
  2. Anyone do laser engraving?
    By Steve Ash in forum General Woodworking Q&A
    Last Post: 04-26-2014, 11:02 AM
  3. First laser kit
    Last Post: 07-28-2013, 11:30 PM
  4. ?? for the Laser folks
    Last Post: 02-11-2008, 02:46 PM
  5. Segmented Pen with a Laser
    By Pete Simmons in forum Lathe Project Showcase
    Last Post: 01-05-2008, 06:22 PM
