Results 1 to 10 of 12
Thread: Router question
    Jan 2009
    Carthage,Mo
    880
    Router question
    Looking to invest in new 1/2inch collet router. Have three 1/4 inch routers but want the bigger for my router table. What are some recommendations?
    Looking at DeWalt but not to sure. Unit would not get heavy use , just a hobby type .
    Thanks for the input.
    David
    YescI did have good birthday with family. Now to recover.
    868
    Quote Originally Posted by David Johnson View Post
    David
    The Makita 3612C, 3 1/4 hp is a 1/2" monster in a router table! That's a good thing! I had 2 of them in LV router tables at one time. They did everything I asked them to do.
    Everything I did was hobby!
    Mack C. in Brooklin ON
    It feels great to sell a pen,
    I am a proud supporter of
    Jan 2015
    Spring Hill Kansas
    16
    In my table I have the Porter Cable 7518 with speed control. Plus the Woodpeckers PRL-V2420 router lift. I have had it for 10 years now and haven't had any kind of problems with either one of them so far. I know its close to 700.00 for the pair and that's a lot of cash to dish out at one time. I use it on about every project I have done over the years from swinging a 1/8 in straight bit up to and including the massive 3 1/2 in raised panel bits for doors and drawers.......
    Thomasville, GA
    5,987
    I have the Porter Cable 75182 motor in my router table. The 75182 is the motor only, so you save some money. Here it is on Amazon.
    When I ordered, I also got the 1/4" collet as well as the 1/2".
    Bill Arnold
    The Porter Cable 7518's have a loyal following as do the Milwaukee 5625's. Other folks have other favorites. I use a 6525 in a Woodpecker PRL. If you are not ready for a lift, the Milwaukee comes with a t-wrench and =above the table adjustment features. Its not equal to a lift but, I used mine this way for quite some time before making the move to a lift.
    5,167
    Yeppers. PC 7518 plus the Woodpecker lift system. Cat's pajamas sort of a real shaper. However, for some a bit less robust and a bit fussier, any 3 1/2 diameter router motor body of any brand (that uses bearings, not bushings) will do fine. I had PC 690's in router tables for years. Occasionally my PC 890 lived in one for a bit. Got stuck on Porter Cable years ago because of a school workshop program had them and they never broke. However, manufacturing is no longer that robust, so pick the color you like and go for. Variable speed is well worth the bucks as well.
    East Freeetown, Massachusetts
    3,014
    I can't find a US made router. Seems they all outsourced to China.
    Makita "might" be made in US, or any number of other countires.
    I have had a Hitachi M12V in my router table since er- about 2003 or so. Never had a single problem with it.
    Thomasville, GA
    5,987
    PM sent.
    Bill Arnold
    Apr 2008
    Independence MO
    557
    David
    While I am similar to above (picked up my first 5625 via a Black Friday sale, years ago, my second was on Ebay and the guy thought it died, symptoms listed told me otherwise), the Porter Cable is more the standard and tends to have more of the default additions for its baseplate.
    That said here, let me go against the grain here................
    You said for the router table, but you didn't say DEDICATED to the router table. That makes a HUGE difference in my view, as you could want a larger collet at some point in a hand held router. If that is the case then there are a couple good Dewalt models (multibase or plunge), as well as the Bosch 1617 series, with multiple bases, that I would recommend.
    Do you really need a 3+ hp router for the table yet, or a stronger 2+ hp to use either freehand or in the table?
    Nov 2012
    Wapakoneta, OH
    610
    I also have the 5625 in my table with a PRL, and that might be my recommendation (it was preceded by a 7518 in the same lift). But the 5625 I have is an older one that was made when Milwaukee was an American company. Not sure if the new ones are up to snuff, but I guess that applies to all of them anymore.
  1. CNC Router Question
    By Dan Mooney in forum New Tools
    Last Post: 03-11-2010, 08:51 PM
  2. Router bit question.
    Last Post: 01-30-2009, 01:13 AM
  3. router bit question?
    Last Post: 01-02-2009, 10:37 PM
  4. Router Question?
    By Charles Hans in forum New Tools
    Last Post: 08-07-2008, 05:19 PM
  5. HELP! Router Bit Question
    By Warren White in forum General Woodworking Q&A
    Last Post: 02-11-2008, 04:35 PM
