Results 1 to 9 of 9
Thread: What the heck!
    Oliver Springs, TN
    1,726
    What the heck!
    On the router table I was cutting a few rabbets 3/8 x 3/8. First two went fine. next one not so well! I started the cut and got about 1 1/2" in and BANG! the board goes flying. After checking to see if I was leaking any red juice and changing my pants. I started thinking what the heck! I then started looking for what caused it to happen. I had noticed after the board went flying the router was making an odd noise. I checked the bit and this is what I found. Click image for larger version.
Name:	rabbit bit face.jpg
ID:	94498Click image for larger version.
    I'm just glad the carbide was captured in the wood and I didn't take a shot!
    What do you think happened?
    Jan 2015
    Spring Hill Kansas
    16
    One or two things that come to mind here.
    1. Bit has been dropped at one or more times in its life
    2. Manufacturing process wasn't great.
    3. Router speed was to great for this bit.....
    5,167
    Carbide is brittle. If you didn't hit something really hard, then I'd suspect the carbide to be defective. Stuff happens. Good when you are only the spectator. Much hairier when you are a participant.
    12,247
    Wow lucky break John. Glad u found no red sauce on yourself.
    What make of bit is it.?
    Oliver Springs, TN
    1,726
    Never been dropped. It's a whiteside Rob.
    4,698
    That ^^^^
    and glad you didn't get bit!
    13,356
    Whoa, Looks like the entire carbide came free of the bit? Zoiks!
    East Freeetown, Massachusetts
    3,017
    Looking at the bit I can make some assumptions
    1) The braze did not fail
    2) There is a clean break of the carbide
    3) There is a thick strong piece of carbide that broke
    From what I can see I would not blame it on cutter failure.
    With that said I would look then at setup.
    If the wood cocked in the cut is would grab the carbide and pull it really hard and really fast into a cut too deep for the cutter to handle and snap off the carbide. Hence, it is jammed into the wood. It could have been a quick jerky movement of shaking that pulled the wood in.
    If there are sufficient mechanical hold downs for the piece (feather boards) then I might question climb vs conventional cutting. I might also question RPM or feedrate.
    I wonder - were you trying to take full depth cuts and hand holding?
    But - my guess is in the setup somewhere.
    I see two good things here; one for sure and one probable. First, no injury . Second, I had a keyhole bit fail very unceremoniously. I offered to ship it to white side just so they could check to see what happened. They unceremoniously sent me a new bit ;-) I have their rabbet set and have used it to the point where it went in for sharpening; still going strong (?).
  1. Scared the heck out of me
    By Bob Gibson in forum Safety Tips
    Last Post: 07-10-2016, 05:44 PM
  2. What the heck is that?
    Last Post: 11-02-2014, 12:49 PM
  3. So, where the heck has Rennie been?
    By Rennie Heuer in forum Off Topic Discussion
    Last Post: 11-30-2009, 03:03 PM
  4. The heck with the tiller, this is what I need
    Last Post: 05-04-2009, 03:20 AM
  5. What the Heck Happened Here?
    By Vaughn McMillan in forum Site Questions and Test Posts
    Last Post: 12-08-2006, 03:13 AM
