Results 1 to 5 of 5
Thread: Twin dressers project progress
    Vacaville CA.
    100
    Dresser project progress
    This is model of 2 dresser’s I am building that I drew in sketchup. I am a bit of a beginner in sketchup and the model is not 100% accurate in relation to my final plan drawings.
    My first step in the project was to veneer 3/8” MDF panels for the side frame and panel assemblies. Curley maple veneer and ¾” cherry. Side frames are tongue and groove joinery done at the router table. The assembly is made a little over size in length so the ends can be trimmed to final size after glue up.
    The next step was to build the dust frames which are ¾” maple ply frame and panel with a ¼” panel, Dust frames are joined to the side panels with dadoes.
    Next step is to build the face and back frames. The back frames are a frame and panel assembly as well. I use the cutoffs from the curved styles to aid in clamping.
    The face frame joinery is pocket screws and glue. My plan calls for inset drawer fronts. I am dialing in the fit of the drawer fronts before I attach the face frame. I use 1/8” shims to gauge the gaps between the pieces. I carefully sneak up on the final dimensions of the drawer fronts with the joijnter to get the fit just perfect.
    That’s it for now. More progress when I make some.
    12,264
    4,701
    Did you pattern route the curves as well?
    9,077
    This is gonna be great. Thanks for taking us along. As to the use of SketchUp. Even my highly detailed drawings get varied from during the build. I consider them a guide and a complex joinery "what-if" or assembly sequence engine mostly. Side note . . . love the Pro Plan router table dust bucket ;-)
    Vacaville CA.
    100
    Yes, any time I have curved components I create a MDF template for pattern routing.
  1. Radiused Laminated Platform Bed/Dressers
    By mike marvel in forum Flatwork Project Showcase
    Last Post: 11-24-2011, 01:28 PM
  2. Replies: 156
    Last Post: 04-09-2011, 06:53 PM
  3. Desk project progress
    By Eric Eckman in forum Flatwork Project Showcase
    Last Post: 11-15-2009, 02:38 PM
  4. Chair Project in progress*** updated partial glue up***
    By Russ Massery in forum Flatwork Project Showcase
    Last Post: 10-16-2008, 10:35 PM
  5. The Twin Twin Bench (pic)
    By Chris Billman in forum Flatwork Project Showcase
    Last Post: 01-12-2007, 05:45 AM
