Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
Thread: Band Saw Riser
    S E Washington State
    3,777
    Band Saw Riser
    I have a Grizzly G0555X band saw. I am beginning to wish I had more resaw capabilities, i.e., height-wise. I have put off getting a riser block for it because I have quite a few nice blades for it now that will be become worthless to me if I change the saw. But, I also like scrolling the bark edge wood, which is normally not available in the thickness I want.
    My question is, are this riser blocks good. I'd like to hear from people that have them on their saws, pros and cons.
    Thanks.
    "We the People ......"
    Oct 2007
    Nova Scotia, 45N 64W
    1,128
    I bought a riser kit for my old 1hp Rockwell/Delta 14" from Iturra Design a couple of years ago and Larry helped me set it up on his summer tour. I also got a "Woodslicer" 5/8 resaw blade and use it just for that purpose now. I haven't used it much for the full 12" capacity, but if you take it to that limit with the hp I have, you'd need to be patient. I'm setting up a General 15" for finer curved work.
    The expanded saw works great. No regrets. A big resaw machine would be nice sometime, but it's way down the list.
    29,394
    I put a riser on my Shop Fox W1706 (pretty comparable to your G0555X) when I first bought it, but have used the extra capacity a lot. My saw only has a 1hp motor compared to your 1.5hp Grizzly, and it does fine as long as I use good blades and don't try to force the cut. Yes, you'll forfeit some of your existing blades, but you might be able to recoup some of your money by selling them here or on Craigslist.
    And when you buy your new blades, I urge you to check out Ellis blades. As good or better than the "name brand" blades at less than half the price. You'd be wanting blades from the "Flexback" list here:
    http://www.ellissaw.com/Band-Saw-Bla...ade-stock-list
    And if you're slicing up logs for bark-edge scrolling blanks, I'd strongly suggest making a good sled to hold the logs. Cutting logs (and other round stock) can be tricky and dangerous on bandsaws.
    Thomasville, GA
    5,523
    ... And when you buy your new blades, I urge you to check out Ellis blades. As good or better than the "name brand" blades at less than half the price. You'd be wanting blades from the "Flexback" list ...
    I can't help you on the riser question, but I'll give a real big DITTO for Ellis blades. Call them, tell them what you want to do and they'll steer you in the right direction on blades.
    Bill Arnold
    NRA Life Member
    Member of Mensa
    Live every day like it's your last, but don't forget to stop and smell the roses.
    3,777
    Thanks for the input. Really thinking serious about it. I will wait a little while, I am one of those that gets it in my head I gotta have something, and them use it a couple times and move on, or after I order something I get good, stern advice why I shouldn't have. This usually comes via my wife,,,,,
    May 2009
    Lafayette, Indiana
    2,206
    Paul, I have the Grizzly G0555X Band Saw with the risers installed. I've had them since day one. They work well. Saw will cut very well with the right blades. I have been using Ellis blades as others have mentioned. I've used 1/4", 1/2" and 3/4" blades.
    Sent from my iPad using Tapatalk
    11,839
    Paul I have a delta 14" bs and it is a 1.5hp motor and shortly after getting it I put the riser on for same sort of reasons. Run all sizes of blades on it and no issues.
    Go for it life's too short and its not huge bucks really.
    13,082
    Quote Originally Posted by Tom Baugues View Post
    I'm with these fellers. I've got a delta I put a riser on day 1, ellis blades. I have never regretted the purchase even once in all the time I've owned it.
    Tellico Plains, Tennessee
    4,179
    I put a Grizzly riser on my 14" Delta band saw... one of my smarter moves... The extra capacity has been a real boon on doing my bowl blanks.
    Biggest problem I've run into is the guide bar for the blade that holds the blade guides on the Grizzly riser was smaller in diameter than the original bar on the delta.... still it works well for me.
    Haven't tried the Ellis blades yet, I buy most of mine from Packard Woods.
    Chuck
    Tellico Plains, TN
    13,082
    So ironic...
  1. Riser Block for a 14" BS?
    By Al Launier in forum Jigs and Fixtures
    Last Post: 11-10-2013, 02:04 PM
  2. Bandsaw riser kit
    By Cass Kucsera in forum Hot Deals
    Last Post: 05-02-2013, 07:28 AM
  3. Grizzly riser kit
    By Chuck Ellis in forum New Tools
    Last Post: 12-26-2010, 09:50 PM
  4. Band saw riser blocks
    By Chuck Ellis in forum Turning Tool Questions and Show & Tell
    Last Post: 02-19-2009, 01:18 AM
  5. bandsaw riser, gonna capitualate
    By Frank Fusco in forum New Tools
    Last Post: 12-30-2008, 10:52 PM
