Results 1 to 10 of 17
Thread: SSQ Sunday SketchUp Quiz
    SE Minnesota
    2,550
    I thought I'd turn the tables a little and see if someone can answer a SketchUp question that I pose. The idea is to get those of you who use SketchUp to stretch your thinking a bit. If this is well received and if I can think of more of these, I'll post them on Sundays and the threads will start with "SSQ"
    If you've read even a little of my blather you know that I stress file size control. Keeping file size down improves the way your computer performs. The geometry, textures and shadows in a model all have to be handled by you machine's graphics card. The more data the card has to handle the slower it runs.
    So, with that in mind here are two copies of the same geometry. This is an aluminum extrusion I imported as a CAD file. My question is, how did I manage to cut the entitiy count in the left hand copy to less than 26% of the one on the right?
    Punta Gorda, Florida
    902
    Are you kidding me? So far I have learned what the drawing thing is, what the turn around thing is, what the push pull thing is and what the hand thing is. I am exhausted and need four Excedrin and some rest.
    Sacramento, CA
    1,367
    I'm not sure I can describe the process used, but I'm pretty sure your end result was to cut down on the number of facets on all those round corners and radii. Now ... how you did that without clicking and deleting each one, I have no idear!
    Edit: My biggest hint was the coloring difference on that circular hole down the center. The one on the left looks like it's shaded using fewer facets.
    Jason Beam
    Sacramento, CA
    SE Minnesota
    2,550
    Allen, you are already on your way to being an expert. Keep working at it and let me know what I can do to help.
    Jason, I like your thinking and reducing the number of segments used to make arcs is a good way to help control file size. In this case however, your guess is incorrect. I didn't change the number of segments used to create any of the arcs. Good eye, though. You did spot probably the only clue I left for what I did.
    SE Minnesota
    2,550
    A couple of additional clues if you look close.
    London, Ontario
    3,383
    Quote Originally Posted by Dave Richards View Post
    I tried to look closer, but when I click on the image and try to drag/rotate it, nothing happens...
    (I would have guessed at arcs also. I also would have guessed that the automatic cleanups -- removing unused components -- wouldn't count either.
    30,237
    Got me stumped, Dave. Jason's idea was along the lines of what I was thinking about, but I see that's not it.
    Do you find yourself trying to rotate pictures on web sites after a SketchUp session? Happens to me all the time.
    SE Minnesota
    2,550
    I was hoping for more guesses by now. Well here's the answer.
    I divided the profile first into quarters and then into eighths. I made those chunks into components and then copied them as needed.The common edges were hidden using Shift and the Eraser tool. Since these element is a component, it doesn't increase the file size as it would if the entire extrusion were made as a single component. The added benefit here is that if you were drawing the element by hand, you'd only have to draw an eighth or quarter of the whole instead of drawing the whole thing. this would save you time.
    902
    Sunday seems to be a real slow day around the forums so I think that is the reason more than anything else.
    London, Ontario
    3,383
    (you can supply your own Homer'esq "Doh!" sound. Slapping the forehead is optional.)
  1. 1950's Car Quiz
    Last Post: 09-16-2012, 02:05 AM
  2. Quick Quiz
    By Bill Lantry in forum Off Topic Discussion
    Last Post: 07-11-2011, 04:10 PM
  3. New Tool Quiz no prizes sorry.
    Last Post: 06-28-2010, 12:21 AM
  4. New Fine Woodworking Quiz
    By glenn bradley in forum Off Topic Discussion
    Last Post: 07-16-2009, 06:49 PM
  5. Just for fun.......Wood Quiz
    By Arnie Grammon in forum General Woodworking Q&A
    Last Post: 02-20-2007, 02:09 AM
