Results 1 to 7 of 7
Thread: Quicky rasp comparison
    4,698
    I was talking with Rob Keeble about rasps and rifflers and had said I'd try to dig up some of the ones I have for comparison and figured I'd just post it here as the site will resize the pictures for me
    These are most of the nicer rasps and rifflers I've collected. The ruler is a 6" ruler for scale.
    First up is (from top-bottom) some Corradi needle files I got from Lee Valley, some Gramercy (TFWW) hand stitched Rifflers (pakistan), and some lee valley detailed rifflers.
    Next is an Aurio curved #8, a Gramercy (TFWW) hand stitched half round (#10 I believe), and a couple of medium iwasaki "mill tooth" files.
    Finally a Shinto saw rasp and a Grobet 4 in hand (has a fine and a coarse side).
    Cuts are all in the same cherry the spoon I recently made came out of. Please forgive the bad hand writing.
    Shinto saw rasp cut.
    Coarse and fine cuts from the Grobet 4 in hand.
    The Aurio (which is fairly coarse)
    The gramercy half round and the Corradi needle file
    Finally the gramercy riffler and the iwasaki medium.
    I didn't test the lee valley detailed rifflers, they're somewhere around 220 - 320 sandpaper (nominally 69tpi but they seem to cut even finer), the finish from them is polished but they don't really remove any meaningful amounts of material. A bit finer than the Corradi needle files.
    Last edited by Ryan Mooney; 03-15-2016 at 04:14 AM. Reason: fix picture order and title.
    12,251
    Hey Thanks a ton Ryan, that's an excellent way of showing them. An observation on my part is that it would do all the sellers a world of good to have some pics like this next to the tool. Illustrates the purpose and benefit very well. Those hand cut TFWW rifflers look real nice in the finish they leave and i like that Grobet hand tool as well.
    Thanks for taking the time and effort to post this much appreciated. The rasps i have in general do more of a tearing job than a cutting job. I think that's what i realize is the difference between the properly created rasp and one that just has bits of metal sticking out to do as much damage as possible.
    4,698
    Yeah, I should do a longer one with some of my other less than optimal rasps just for comparison sake. Some of those leave a more interesting surface texture (to put it nicely).
    The other thing I'm not showing here is the relative speed which varies widely (and is only weakly correlated to surface finish). Perhaps a constant number of strokes? Not sure because there are length differences and how hard you push (not very) also determines the cut speed and quality so there is still a lot of subjective measurement here.
    I was mostly trying for the "best" quality cut on these ones (without going overboard), so mostly took one or two cuts down the centre and then one or two from each side to try to go with the grain some.
    The one nice thing about the really fine needle files is that they still leave a pretty good finish even somewhat against the grain (and indeed this seems to be somewhat true for most "file" type cutters more than "rasp" type cutters the individual teeth seem somewhat more prone to pulling the grain).
    I am a fan of the Grobet 4 in hand for small/medium furniture scale work, it cuts pretty fast, leaves a nice surface, and is pretty good at getting into curves. Its not a real beastly material remover as it is pretty small, and it doesn't leave a "finished" finish, but its a handy fellow to have for that intermediate work.
    13,442
    Excellent post, might be work a sticky or some place it will be easy to find/reference.
    4,698
    Hold that thought.. I think I should extend this somewhat and clean up the "data" a little so its not quite as messy
    Los Angeles, CA
    2,668
    Nice!
    I wouldn't trust the rifflers from Pakistan.
    Welcome to the forum, Jessica.
  1. Quicky and Dirty project.
    By Brent Dowell in forum Flatwork Project Showcase
    Last Post: 11-30-2013, 07:30 PM
  2. Some Quicky Cabs
    By Stuart Ablett in forum Flatwork Project Showcase
    Last Post: 11-27-2010, 04:00 AM
  3. Curved rasp
    By Toni Ciuraneta in forum Jigs and Fixtures
    Last Post: 01-11-2008, 07:42 AM
  4. Just a Quicky Pen
    Last Post: 12-20-2007, 09:49 PM
  5. Just a quicky.........
    Last Post: 11-26-2006, 12:59 AM
