Results 1 to 10 of 14
Thread: cant emphasize enough, the right castors are just as important as any other tool
    new york city burbs
    10,188
    Ive been building cabinets/racks/storage for my tools and things for 8 years.
    I usually get decent castors as it makes life easy.
    For some reason, it took me over 5 years to realize if I didn't figure out a way to move my 22/44 drum sander in and out of shed easy enough, I may never use the thing again, which I haven't recently.
    A few weeks ago, I finally decided, 320 lbs rated pneumatic castors were not doing the job because I constantly had to inflate them, for some reason they would deflate(well, not no reason, couldn't handle the weight.)I figured 4 of them should suffice, but as usual I was wrong. so the drum sander sat in back of the shed.
    I purchased the highest rated blue castors at HF, yes, HF(I don't purchase much from them ever), 600 lbs each. wow.
    Now I can move it in and out of the shed myself, it rolls so easy it even rolls over the grass easy enough.
    I can get it in and out in under 5 minutes.
    good news is Im using it again.
    Been doing a run of boards between projects, and its very, very useful.
    Don't ever skimp on the castors, EVER. Properly weighted decent castors will make your life so much better. Just some advice for the new people starting in with mobile cabinets.
    spend the dough, get the best. always.
    (some of these boards might be from a month or two ago)
    Attached Thumbnails Attached Thumbnails therightcastors 002.jpg   therightcastors 003.jpg   therightcastors 005.jpg
    Human Test Dummy
    Yep, totally agree!
    Dec 2008
    falcon heights, minnesota
    5,610
    that's why i used casters rated for 300+ lbs each for all of my benches.
    benedictione omnes bene
    www.burroviejowoodworking.com
    East Freeetown, Massachusetts
    3,022
    Great advice.
    I will be putting casters under my CNC machine someday.
    I am thinking in the neighborhood of $50+ each.
    The machine is 1500 pounds.
    I can't cheap out.
    12,262
    Can only agree. I put crap on my lumber cart then could not move it. And ultimately had to throw it over and spill the contents to get under it and remove the flattened casters. Then I got serious and ordered some steel backed poly with bearings in axles and 8" diameter. Now she moves.
    Oct 2007
    Nova Scotia, 45N 64W
    1,247
    Just gave me an idea! I have several re-purposed multi shelf greenhouse carts for work/space savers in the barn (storing raw fleece) and there's always a flat tire. Here I go to Princess Auto.
    Thanks Allen
    Great cutting boards, sort of an optical illusion of three dimensions.
    new york city burbs
    10,188
    thanx, I really went through the old lumber and pulled out the knotted up hickory, some old birch, beech, using it all, cleaning up the rack.
    Ill be taking as many as I can fit in the suitcases down to florida in a few months to hand out to my siblings, and nieces.
    Human Test Dummy
    3,022
    One thing about wheels. If they stay in one place for long they can develop flats. Good practice is to be able to take the load off the wheels if at all possible.
    Quote Originally Posted by Leo Voisine View Post
    Great advice.
    I can't cheap out.
    I think I spent just under $50 each for the Zambus Carrymaster AC-300 casters I put under my lathe. They're rated at 375 pounds each and have handled my 600 pound lathe nicely. For your CNC machine I think you'd be looking at the AC-600 casters, rated at 750 pounds each. But I agree with you...cheaping out on casters is seldom worth it.
    5,175
    Agreed. My CNC has 300 pound wheels under it, but it doesn't weight nearly as much as Leo's. I also added these:
Name:	adjustable leveler.jpg
    After I move the machine, I'll just run them down with my cordless driver until the machine is level and call it done. Weight will be mostly off the wheels.
  1. Lumber cart castors
    Last Post: 07-22-2014, 10:30 PM
  2. Important Statistics
    Last Post: 08-24-2012, 02:19 AM
  3. Mobile base swivel castors orientation
    By Mohammad Madha in forum General Woodworking Q&A
    Last Post: 05-12-2012, 01:11 AM
  4. How important is a radial arm saw?
    By Duncan Cheslett in forum General Woodworking Q&A
    Last Post: 10-16-2007, 10:21 PM
  5. ATTENTION PET OWNERS, IMPORTANT
    By Ken Garlock in forum Off Topic Discussion
    Last Post: 03-20-2007, 01:33 AM
