Results 1 to 10 of 16
Thread: More techno geek stuff
    13,466
    Seems like about ever 3 - 4 months, my daughter or wife call saying they left the house for a walk and forgot their keys and the keypad on the garage door won't work. It's either user error, which the pad isn't very intuitive, or the battery is dead on it. And it usually occurs when I'm out of town or at work.
    So I've been playing around with some new devices that utilize the very affordable ESP8266 Wifi chip, the Nodemcu (http://www.amazon.com/Wireless-devel.../dp/B01ACJIAPU). The device can be programmed using it's native language, Lua (http://nodemcu.com/index_en.html), or using the Arduino IDE (http://www.seeedstudio.com/recipe/11...duino-ide.html).
    These are becoming pretty popular for home automation and monitoring systems as they are easy to program and sensors/modules are readily available for just about any type of application.
    Anyway, I've programmed this one to host a web page, which the user must enter a code to open the garage door. They also have to have a device that is on my secured home wifi. So any of my family members that have their phone connected to my wifi can open the door.
    This is the proto type, simply just the nodemcu (3.3v at pins), a logic level converter for 3.3v to 5v connections, and the relay (5v). It has 3 other pins for door sensors to show if the door is opened or closed.
Name:	2016-03-26 18.47.54.jpg
    I tapped it into my opener button to test it out, the door sensors aren't connected yet in this video, and I bypassed the door code for testing.
    With this, any family member can open the door and I can do it for them remotely if need be. I also plan to send some messages to my email when the door is opened and closed.
    13,364
    Now I just need to adapt that to an automated chicken door opener closer thingy
    Excellent!
    4,701
    So the first thing I'm confused by is .. you can park in your garage
    Cool setup, though
    Can you wire the email alarm to a sensor so if the regular opener is used it also triggers? or are you planning to bypass the regular opener all together?
    Very cool. I have no idea how you did it, but the outcome is great.
    13,466
    Thanks Guys. Brent, other than needing to control a motor, should be pretty much the same code. I've got a couple of these motor shields on order to try something similar... http://www.ebay.com/itm/like/351626621523
    Cool setup, though
    Ha, this is her garage, so yes, there is parking in there. Sometimes I can get mine in the shop, but it's a rare occasion. The open/close sensor will work independent of the open/closing relay, so it will notify anytime it changes state. I'm planning to use two of these magnetic switches (http://www.amazon.com/10BS-MC27ST-Ma.../dp/B015OXO1ZW) on each end of the opener's shaft and the magnet will ride on the carrier to trigger the switch that it's by, or show an in-between state if neither are triggered.
    4,701
    That'll work! Those switches did not review well though hopefully yours work better than the ones the folks on amz reviews got.
    For the chicken door wouldn't you want to use a light sensor instead so open when light, closed when dark?
    13,364
    Yep, Simple change, but also need to add the code to control a stepper motor to open/close the door. They want 240$ for one. I'm sure I can build one for less than 30$
    13,466
    The review was accurate, the NC side doesn't work on these, which is fine, I needed the NO side anyway. So I wouldn't recommend them either and will be giving them a crappy review too.
    Mar 2015
    Parker County, Texas
    1,508
    I'm not sure just what to say. It's cool. Very ingenious. But, I'd tell them to quit forgetting their danged keys. I forgot I don't have a garage. I do have a tractor shed, though. It don't have a door, though. Never mind. I guess I need more coffee.
    East Freeetown, Massachusetts
    3,022
    Do you need electricity for that to work?
    My system is a little less tech savy.
    #4 finish nail = 2 cents
    One key = $2.00 ?
    Bank nail into some place secret
    Hang key on nail
    Unlock door - go inside - put key back
    No batteries, works even if electricity is out.
    Certain people know where it is.
    Think you can find the key? Good luck!
  1. question for you techno guys
    By Don Baer in forum New Systems and Builds
    Last Post: 01-11-2016, 05:17 AM
  2. I'm Thinking Dad's Not A Techno Geek
    Last Post: 07-31-2014, 02:08 AM
  3. speeking geek
    Last Post: 10-06-2009, 09:25 AM
  4. mac geek ??
    Last Post: 12-20-2008, 12:00 PM
  5. techno grief
    Last Post: 12-15-2008, 09:40 PM
