Results 1 to 9 of 9
Thread: Big John's Engine Saga continues
    5,172
    This afternoon the goal was to put the engine in the frame. Knew there would be an issue getting the u-joint of the drive shaft onto the engine shaft. There was. Took an hour of fuddling around. Had to finally file the shaft key down some. Then is slipped right on.
    Started dropping the engine mount bolts in. Three went in with no problem. Number four was another story.
Name:	Bolt 4 misalignmentJPG.jpg
    Time to contact the company and let them know their bracket is defective.
    Oh, well. I was tired anyway.
    30,017
    Bummer. What a pain to get that far only to find a fault like that.
    13,361
    Somehow I think you probably already have a plane to get it fixed.
    13,447
    That looks like a problem, hopefully they will correct it...if you don't first.
    East Freeetown, Massachusetts
    3,020
    So Close yet So Far
    Perhaps they only need to send the bracket to you.
    It is a pain when that happens
    3,134
    Maybe this guy could help you or maybe he'll just put a smile on your face.
    Southeast Pa
    2,019
    That is a shame..
    I always wondered how good those re-power kits were. My son has a 317 with Hydraulics that needs an engine... Looks as if you could retro that bracket if they would give yo some compensation... Cut it off move it down weld it back. Be interesting to see if the next one they send fits correctly or is the same..
    I wonder if they messed up or if JD made some changes along the way they weren't aware of... Good Luck with it....
    I am sure you want to get to the loader... I want to see it..
    Mar 2015
    Parker County, Texas
    1,500
    Shoot. I think it's amazing what's been accomplished so far. Totally amazing.
    5,172
    Quote Originally Posted by Garry Foster View Post
    That is a shame..
    I am sure they will replace it. The rail is welded at the incorrect angle for this tractor. Not an easy fix, even for an expert welder. I will keep you all posted. Other than that, I am happy so far. The reviews on this motor via the tractor forums is great. The supplier got good kudos as well, so I am not particularly worried.
    And I too am looking forward to the loader! So much to do first. Hope I took enough pictures to get the tractor back together after the motor is running!
  1. The house saga continues
    By Carol Reed in forum Carpentry and Construction
    Last Post: 06-13-2015, 04:04 PM
  2. bowl gouge saga continues
    By Frank Fusco in forum General Woodturning Q&A
    Last Post: 12-07-2008, 12:59 AM
  3. The planer saga continues
    By Billy Burt in forum General Woodworking Q&A
    Last Post: 11-15-2007, 12:40 PM
  4. Hit a milestone (Painting saga continues)
    By Jeff Horton in forum Carpentry and Construction
    Last Post: 11-11-2007, 05:07 PM
  5. The ATT Dsl saga continues
    By Ken Garlock in forum Off Topic Discussion
    Last Post: 10-30-2007, 11:51 PM
