Results 1 to 9 of 9
Thread: Shooting Board with Lee Valley Track
    This is the latest application of the method I have settled on for these things. This one gets multiple fence positions and a 45* fence instead of a triangle that attaches to the 90* fence. The "hook" is also moved up from the end by about 2-1/2". This is more comfortable for me based on my height, reach, etc.
    Simple and quick to make (LV track not required but, really nice Xmas gift). I have found that it is nice to have a little wiggle room now and again so I have moved that feature forward onto this version. I make my 90* fence adjustable about a degree each way and the 45* fence adjustable a couple of degrees each way. The knob and fender washer keep the fence put once set until I change it.
Name:	Shootingboard v2 (1).jpg
ID:	95258Click image for larger version.
Name:	Shootingboard v2 (2).jpg
ID:	95259Click image for larger version.
Name:	Shootingboard v2 (3).jpg
ID:	95260Click image for larger version.
Name:	Shootingboard v2 (4).jpg
ID:	95261Click image for larger version.
Name:	Shootingboard v2 (5).jpg
    17,474
    did it dial in ok glenn? on either of the settings?
    The plane works like a champ. Must've been that expert help I had with it. A good test is to shoot a couple of pieces with prepared surfaces to reference from, then place them end to end against another reference surface. If the faces line up both directions, you're generally OK. These are two random pieces out of the scrap bin with some surfaces planed true. They are different thicknesses and the other surfaces are rough but, you get the idea.
    13,452
    Very nice Glenn, I need to give one of these a shot some day, those butted edges look perfect.
    May 2010
    Orland Park, Illinois, USA
    278
    Glenn,
    Very nice and well thought out. Will have to add this to my ever growing to-make list. Thanks.
    Yorktown, Virginia
    5,017
    Humm....that's a really nice set up. Very tempted.
    4,699
    I've been using my low angle Jack as a shooter, but have wondered if the shooting plane is enough easier to justify it. Still kind of on the fence.
    A better shooting board like this setup would be worth doing anyway. Currently I'm just using a primitive bench hook as a dual duty setup but my bench isn't perfect so it takes a bit of fiddling at times.
    My board for the LAJ has a retaining strip that works quite well. If it wasn't for Xmas and the Lee Valley wish list I would still be using it.
ID:	95266 . Click image for larger version.
ID:	95267 . Click image for larger version.
    4,699
    I'm assuming that that's a Derek Cohen inspired hot dog handle? That's also been on the long list of short things to make
    http://www.inthewoodshop.com/ShopMad...ck%20pics.html
    I do have some UHMW floating around.. might just be enough to make something like that.. hrmmm... You have way to many good ideas
  1. Shooting Board Rev 1 - Done
    Last Post: 09-27-2012, 02:53 AM
  2. Mitre Shooting Board
    By Darren Wright in forum Designs, Plans and Sketches
    Last Post: 05-10-2012, 08:27 PM
  3. Shooting Board Guide Rail
    By glenn bradley in forum Neander Tool Questions and Show & Tell
    Last Post: 06-23-2011, 03:01 PM
  4. shooting board material
    By Mark Kosmowski in forum Neander Tool Questions and Show & Tell
    Last Post: 06-10-2009, 05:43 PM
  5. shooting board accuracy
    Last Post: 06-10-2009, 05:02 PM
