Results 1 to 9 of 9
Thread: old fashioned casement window hardware ?
    5,533
    I grew up visiting my grandparents who rented a series of cabins on a particular lake in the Pocono mountains in PA. One of the camps had these really cool casement window hardware, instead of a hand crank there was a metal bar mounted to the window, hinged at one end, with a right angle bend on the opposite end that you'd put in whichever receiving hole on the window sill you wanted, there were 4 holes in a row near the hinge side one set in a bit which allowed you to pull the window closed.
    depending upon which hole you put the bent end into, you could have it open at several angles, or fully closed.
    pardon my crude skp sketch, but that's about as good as I could get to show the mechanism (with my crude skills). Does anyone know of:
    what they are called ?
    a source for said mechanism if available?
    for all I know they were fashioned in the machine shop at the camp (there is a staff with a shop to effect repairs on the individual cabins as needed), though I doubt it.
    the camp dated from roughly the 1930's if that helps any.
    Attached Files Attached Files
    -Ned
    Tokiwadai, Japan
    2,882
    Ned,
    Here's something that might help: Casement Window Stay
    http://houseofantiquehardware.com/s....category.83/.f
    Greg
    Floydada, Tx
    1,941
    Do you have any really old, small towmn hardware stores around you? If so, they may have them tucked away in the back room. We had a old hardwarestore complete with qswo creeky floors that stuff that dated back to the turn of the century.
    Tokiwadai, Japan
    2,882
    Quote Originally Posted by Al killian View Post
    We had a old hardwarestore complete with creeky floors that stuff that dated back to the turn of the century.
    Al,
    I think Ned is looking for stuff older than that...
    30,237
    Greg's link seems to be lower priced, but Crown City Hardware in Pasadena has lots of old restoration stuff.
    http://www.restoration.com/index.html
    and specifically this page.
    Ned, you can take a look at Truth Hardware. And you can also do a google on 'casement hardware'.
    5,533
    thanks guys! I'll check those out.
    Haven't found the exact style that I recall, but those are getting 'warmer'.
    I'm just doing research about window options for my shop, which should break ground later this week. I Hope.
    -Ned
    9,112
    Floydada, Tx
    1,941
    Ned, Here is a link to a place I found.http://www.vandykes.com/search.php?q=casement+hardware
  1. Old fashioned molding cutter.
    By Ryan Mooney in forum Off Topic Discussion
    Last Post: 01-30-2016, 03:39 AM
  2. View out the window
    Last Post: 11-01-2011, 12:02 PM
  3. big window question
    By Frank Fusco in forum Carpentry and Construction
    Last Post: 01-12-2011, 03:00 PM
  4. why whole new window for PMs ?
    By Frank Fusco in forum Site Questions and Test Posts
    Last Post: 12-28-2008, 04:40 PM
  5. Old Fashioned Dust Collector
    By Travis Johnson in forum General Woodworking Q&A
    Last Post: 09-28-2007, 10:46 AM
