Results 1 to 10 of 13
Thread: drawing stud walls
    Lowndesville,SC
    31
    drawing stud walls
    I lost all info on my computer when I thought I had it all backed up but didn't.I had an add on for sketchup where I could put in the size of the wall and it would put in the correct amount of studs.I have W10 on another hdd and have 2016 on it,so I probably need an add on for the new sketchup.I don't have the other add on or remember the name of it.What I'd like to know is if there is a new one or where I can get the old one.I say add on,but I guess I should say extention.If anyone has an answer I would be very thankfull for the info.
    Be nice to people on the way up,you'll see the same people on the way down.
    13,443
    I believe the plugin is called "house builder". I think I've installed the older version on a newer version on sketchup. I'll have to look at my shop computer next time I'm up there.
    Sent from my SM-G920P using Tapatalk
    Lowndesville,SC
    31
    It is called "house builder",and I found a down load but I can't find how to open RB files in W10,so I don't know if it will work in the new OS.I'll keep trying until I figure it out,If I can.
    Lowndesville,SC
    31
    Thanks for the help Darren.
    DAve
    13,443
    I think you just have to manually install them to the plugins folder by copying them there. Im not sure if the folder is still under sketchup or moved to the users appdata folder though. A restart of sketchup would be required.
    13,443
    Here's a thread explaining how to either rename the zip and use the extension installer, or to copy to the plugins folder...http://forums.sketchup.com/t/plugin-...stall/10267/10
    13,443
    Decided to install this on my laptop, I downloaded the plugin from here: http://sketchucation.com/click.php?u...556663#p556663 (if you're not a member, there is a free way to sign up, just click the link below the subscriptions they list).
    Once downloaded, open sketchup, go to Window>>Preferences, then click the Extensions link on the left side of the dialog. Click "Install Extension", then navigate to where you downloaded the .rbz file, choose it and click to install. You will probably get a security warning, I clicked Yes, should give you a message that it was installed.
    Lowndesville,SC
    31
    Thanks Darren,I got it loaded.It don't work right in 2016,but nothing does in W10.We'll have to learn to get along with it or not have computers I guess.
    Thanks again Darren,
    Dave
    13,443
    Quote Originally Posted by Dave Willis View Post
    Dave
    No problem Dave, I was actually telling my brother about the plugin the other day, so needed a refresher in loading it. BTW, if the new menus in W10 bother you, you might download and try the Start10 start menu button, makes the start button just about like using Windows 7. It has a 30 day trial, but only $4.99 to buy... https://www.stardock.com/products/start10/
    Lowndesville,SC
    31
    Thanks for all your help Darren.
    Dave
  1. Stud finders
    By Jonathan Shively in forum New Tools
    Last Post: 09-10-2014, 07:14 PM
  2. Stud finder
    By Dan Mooney in forum New Tools
    Last Post: 03-28-2014, 03:02 AM
  3. It's a BOY! It's a STUD! It's a GRIZZLY!
    By Al Launier in forum General Woodworking Q&A
    Last Post: 12-31-2012, 12:35 AM
  4. Stud wall screws
    By Dennis Thompson in forum Carpentry and Construction
    Last Post: 07-20-2010, 05:05 PM
  5. Zircon And Other Stud Finders
    By Boyd Gathwright in forum Carpentry and Construction
    Last Post: 01-19-2007, 09:34 PM
