Results 1 to 7 of 7
Thread: #3 Gloat
    Charlotte, NC
    1,487
    #3 Gloat
    Found a nice little toy on that big auction site, complete with the requisit paint spatter! Overall it is in very good shape. I brushed a little surface rust off, no pitting, and need to square the iron. I would like some advice/recommendation. The tote is a little loose and the screw is bottomed out. How can I fix this short of replacing the tote? I may be able to find a couple brass washers to shim it with, but there is not much clearance.
    The Heart of Dixie
    4,268
    Shorten the screw slightly?
    Custom built boats and Kits
    Steve Clardy Guest
    Small brass washer, or cut the shaft off a tad
    Central NY State
    3,375
    I've used the grinder to remove 1/8" or so off the threaded rod.
    Charlotte, NC
    1,487
    Thanks guys. Looks like the rod's gonna get it!
    Decatur, Illinois
    177
    don't forget to put a nut on the shaft before shortening...then use the nut to clean up the threads that may be damaged by grinding, sawing, etc.
    99% of lawyers give the rest a bad name...Steven Wright.
    Steve Clardy Guest
    Quote Originally Posted by Clark O'Neill View Post
    Doubtful he can find a nut to fit it.
    Rod is an odd size, 32nd under a 1/4"
  1. Old Saw Gloat
    By Cynthia White in forum Old Iron
    Last Post: 12-03-2011, 02:06 PM
  2. I have to gloat....just a little
    By Nancy Laird in forum Turning Tool Questions and Show & Tell
    Last Post: 07-03-2009, 10:48 PM
  3. Thanks - & Gloat
    By Norb Schmidt in forum General Woodturning Q&A
    Last Post: 06-09-2008, 01:35 AM
  4. Lathe motor question and gloat..UPDATED NOT A GLOAT ANYMORE
    By Jeff Bower in forum General Woodturning Q&A
    Last Post: 05-20-2008, 07:17 PM
  5. Lathe Upgrade - Product Gloat, but not Price Gloat
    By Thomas Smith in forum Turning Tool Questions and Show & Tell
    Last Post: 05-09-2007, 08:11 PM
