Results 1 to 10 of 22
Thread: tostonero project
    Dec 2008
    falcon heights, minnesota
    5,610
    tostonero project
    this is a prototype, and to be given to one of our friends at church. it is used to make a variant of tostones, that are shaped like a cup, the other variation is outright flat. to make them, take an average plantain, deep fry it a bit, then take it to the tostonero, and smash it flat, then finish frying it. with the other one, it is put into a press, and it makes a sort of plantain cup, which is then filled, and cooked. i'm using some odd cuts of cherry for this one. the finish will be good old mineral oil.
    Attached Thumbnails Attached Thumbnails 001 cherry boards planed.jpg   002 boards cut to length and width.jpg
    benedictione omnes bene
    www.burroviejowoodworking.com
    12,264
    Well Dan you sure got my fingers searching google.
    Here is what i found but i am trying to put the pieces together.
    So whats the filling ?
    Dan i was raised with having fried banana for breakfast when there are over ripe banana in the house. Thing is they very sweet so one gets stretched between two people. But not had fried plantain. Are they sweet once fried.
    http://www.eltostonero.com/images/F-...RA%20COMBO.JPG
    http://www.eltostonero.com/images/B-...%20RELLENO.JPG
    You planning on cutting these with your cnc or template and router?
    Dec 2008
    5,610
    actually, as this is a prototype, i will be cutting the ends round.
    4,702
    Welp there's the extended word of the day.. tostonero!
    We've made tostones before but only the flat kind and those we just made with a fork. I'll be interested to see what these ones look like if you get to try the product post production. I'm curious about the filling as well... the picadillo stuffed ones look pretty tasty!
    Rob,
    The Plantains are a bit of a starchy banana, not super sweet. Usually (at least when we made them, Dan correct as needed for your variant) we'd use them a bit green so even less sweet/more starchy. The first frying softens them up a bit so you can squish them good and flat then the second frying makes them nice and crispy. We mostly made the flat ones when we were in Hawaii and could get reasonable plantains - and ate them with Philipino style banana ketchup (yep ketchup made from bananas, https://en.wikipedia.org/wiki/Banana_ketchup).
    4,553
    Well done my research and now I'm hungry.............Way ta go Dan
    A Turn N Time
    Frog Pond Guitars
    13,468
    Dec 2008
    5,610
    got the blank glued up today. too hot for anything else. may be able to trim it up a bit tomorrow, depending on errands and such.
    Yorktown, Virginia
    5,022
    The Doc said my tostonero levels were a bit low, so I got some plantains and now everything is fine!
    4,702
    I think you meant:
    every thing is fried
    Yorktown, Virginia
    5,022
    You got that right!
  1. tostonero mk 2 project
    Last Post: 06-03-2016, 02:47 PM
  2. Need simple project idea for Boy Scout woodworking merit badge project
    By Jerry Ingraham in forum General Woodworking Q&A
    Last Post: 02-04-2012, 07:52 PM
  3. BF for a project
    By Eduard Nemirovsky in forum General Woodworking Q&A
    Last Post: 07-11-2008, 02:46 AM
  4. Done! Pics! better a small project than no project at all
    By Mark Kosmowski in forum Flatwork Project Showcase
    Last Post: 04-07-2008, 11:28 PM
  5. First Project
    By Gene Miller in forum Flatwork Project Showcase
    Last Post: 10-08-2007, 02:01 PM
