Results 1 to 6 of 6
Thread: cutting board save project
    Dec 2008
    falcon heights, minnesota
    5,610
    a new and unexpected project! well, the last board, on the last pass on the planer got a bite taken out of it. instead of pitching it into the pile of wood that has no name, i thought, i can plane it down to flat again and see what happens. so, after a few more rides in the planer, saved the blank with not too much of a loss of lumber. then it was off to the table saw, and the awaiting sled. cut it down to as many saveable strips as possible (due to the loss of lumber). turned them up on end grain, flipped every other one, and decided that it would make a nice housewarming gift for my nephew. now it resides in the clamps (using the good titebond 3), awaiting a trip to the big sander, with its thicker cousins.
    Attached Thumbnails Attached Thumbnails 001 planer bit this one.jpg   002 planed smooth again.jpg   003 strips cut.jpg   004 turned on end grain.jpg   005 every other one flipped.jpg
    benedictione omnes bene
    www.burroviejowoodworking.com
    Feb 2012
    2,749
    Nice save!
    Cheers,
    Roger
    Jan 2009
    Carthage,Mo
    886
    Came out just fine. Do you program to assort cuts for end grain? Or just do your thing? I make these and let my mind run wild.
    Looks real good.
    David
    Dec 2008
    Portland, Oregon
    1,898
    Nice Save, that really took a big snipe out of it!
    Jesus was a Woodworker
    North West Indiana
    6,098
    Dan, how bad does the glue "fill up" your sand paper on your sander? Does the big eraser clean up the glue clogs well?
    Nice cutting boards.
    Jon
    Dec 2008
    5,610
    thanks guys!
    jon - i don't have too bad of a problem with that. i manage to knock off most of the squeeze out after a few minutes when it is pliable, then the sander at the local cabinet shop has an easier go of it.
  1. cutting board project
    Last Post: 06-11-2016, 02:33 AM
  2. Cool Cutting board project + CNC work
    By Brent Dowell in forum General Woodworking Q&A
    Last Post: 11-18-2015, 05:18 PM
  3. Cutting Board - How Do I Do It
    By Pete Janke in forum General Woodworking Q&A
    Last Post: 04-01-2012, 02:14 AM
  4. cutting board
    By Frank Fusco in forum Flatwork Project Showcase
    Last Post: 05-09-2010, 09:05 PM
  5. My First Cutting Board
    By Jeff Bower in forum Flatwork Project Showcase
    Last Post: 09-01-2009, 11:00 PM
