Results 1 to 10 of 21
Thread: Cutting Metal
    Los Angeles, CA
    2,668
    Cutting Metal
    Looking at several options to cut metal: Harbor freight 4 x 6 Band Saw or Grizzly G0622 vs Metal Chop saw like Dewalt DW872 or Evolution 380 Raptor.
    Any one has any experience with one of the above. Pros & Cons? Review. Another preferred brand within the same category?
    I know there are other options like plasma, angle grinder, abrasive disc etc but I am looking for a less expensive method and cuts that don't require correction.
    5,167
    I gave my metal cutting chop saw away. Just didn't do it for me. Got the HF bandsaw. Think it is a good bang for the buck. Handles everything I throw at it. YMMV.
    Southeast Pa
    2,019
    Quote Originally Posted by Mohammad Madha View Post
    I have the import bandsaw and have use it often. But the question is what are you wanting to cut. Mine doesn't cut very square in the vertical direction and all the tweaking in the world hasn't fixed it. Others have been square out of the box. Mine is an older version from Grizzly. I actually bought it in a whim when I was buying my 14 inch band saw to keep me from being tempted to cut metal with the 14 inch wood saw. I have ended up using the metal tutting bandsaw much more than the 14 inch woodsaw. I am assuming that none of the you mention are good with thin metal without doing a little mucking around..
    Garry
    13,356
    If you've got the room, the 4x6 would be nice. I've got the handheld metal bandsaw from HF and I have to say, It's lasted longer and done more work than I ever expected from it.
    http://www.harborfreight.com/10-Amp-...Kit-62800.html
    13,432
    Quite honestly between my 4" angle grinder with the thin HF cut-off wheels and some metal blades in my jig saw I can cut things pretty accurately with very little cleanup, but YMMV. Those little bandsaws do look appealing, especially when you add the stationary base to use it like a regular bandsaw. http://www.swagoffroad.com/SWAG-V30-...able_p_55.html
    13,356
    That table is a cool idea.
    Not 130$ worth of cool, but I bet I could rig something up that would work the same!
    12,246
    I just purchased a Hf bandsaw and between it an my 4 1/2 " grinder they will do for what i want to cut up.
    Check out this video it shows a simple stand for Hf portable bandsaw.
    One tip if u want one, hold out for the sale price $99 US.
    ALSO make sure to buy some metal blades for it ..they available at HD and Lowes.
    https://youtu.be/Yz9oT7ltl4M
    Check out how diresta makes these saw horses and makes use of a saw like this to give you an idea of what its good for,
    https://youtu.be/1sn62Cq5xXY
    Also if you have a clear idea of lengths of metal, then the metal supply company will usually cut to length your tubing needs. Whats left is then just smaller cuts.
    13,356
    That's a pretty cool looking stand too.
    Picture worth a thousand words, or 4:51 of video.... Could whip something like that up from scrap I've got laying around.
    12,246
    Thats what i intend to do as soon as i get power sorted for my new welder.
    Los Angeles, CA
    2,668
    Thanks guys.
    Carol, good to know that it is a reliable machine.
    Garry, I will be cutting steel tubes less than 2 x 2 in size and cut steel pieces less than 1/4" thick. Simple stuff.
    Thanks for the portable band saw suggestion. Something to think about.
    Rob, thanks for the video links. I am sure I can weld up a stand like that, once I get my welder. Darren, that table is nice but just like Brent I find it expensive.
  1. Gun Metal
    Last Post: 08-19-2014, 09:23 PM
  2. I'm Looking To Buy a New Metal Cut-Off Saw......
    Last Post: 04-27-2013, 01:01 AM
  3. Cutting small parts without cutting me..........
    By Ken Fitzgerald in forum Jigs and Fixtures
    Last Post: 01-28-2013, 04:30 AM
  4. Metal Cutting Blade
    By Antony N. Lord in forum Off Topic Discussion
    Last Post: 03-16-2008, 04:33 AM
  5. WW Machines and Metal
    By Travis Johnson in forum Designs, Plans and Sketches
    Last Post: 12-03-2006, 04:40 PM
