Results 1 to 9 of 9
Thread: repairing a chip question
    Oliver Springs, TN
    1,726
    A friend has an electric acoustic guitar. To make a long story short it got dropped and chipped on the lower right hand corner and he asked if I could fix it. How would you repair this? I've got some ideas, but wanted some input. He's going to have it re-dipped so the repair will be covered so it only needs to be flush and doesn't have to match the camo pattern. He's on the mossy oak pro staff and they will do the dip for free.
ID:	95841Click image for larger version.
ID:	95842Click image for larger version.
    On something like that, I think I'd break off any of the cracked finish and use Bondo to make the surface flush again.
    5,322
    Yeah, Bondo - or one of the auto body polyester finishing putties. I've used one called 'Icing' that gives a very smooth finish..
    Oliver Springs, TN
    1,726
    Thanks guys, that's the way I was leaning.
    Apr 2009
    Outside the beltway
    5,259
    I'd use the Trip 7 2 part 5 minute epoxy and as it sets mold it to the shape and smooth out.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    12,260
    Dave is this the stuff you referring to?
    http://www.amazon.com/PC-Products-Tw.../dp/B008H4QSAW
    Nov 2012
    Wapakoneta, OH
    611
    My first thought was Bondo or wood epoxy putty as well. But I can't help but wonder if that small amount might change the tone of the guitar ever so slightly.
    I long for the days when Coke was a cola and a joint was a bad place to be (Merle Haggard; 1939-2016)
    Quote Originally Posted by fred hargis View Post
    That guitar has so much paint and dipped plastic camo on it, there is probably no tone to speak of anyway. It likely sounds fine when it's plugged in and amplified, but as a living room (unamplified) guitar, I'd bet it sounds pretty dead. An inch of Bondo on the edge of the body won't change that.
    Apr 2009
    Outside the beltway
    5,259
    Rob not the same brand but the same product. I do a lot of porcelain repair with this.
    I buy clear so I can do my own tinting.
  1. repairing a lamp shade base
    Last Post: 07-19-2015, 02:56 PM
  2. Repairing Bandsaw Blades
    Last Post: 09-28-2013, 12:01 PM
  3. Need your help with repairing my Delta Table saw.
    By David Trompower in forum Old Iron
    Last Post: 02-14-2013, 04:13 PM
  4. Repairing a Crack in a Guitar Top
    By Dan Mooney in forum General Woodworking Q&A
    Last Post: 11-09-2012, 06:19 PM
  5. Cyclone chip barrel to lid seal question.
    By Jim O'Dell in forum General Woodworking Q&A
    Last Post: 11-22-2006, 06:37 PM
