Results 1 to 10 of 11
Thread: tostonero mk 2 project
    Dec 2008
    falcon heights, minnesota
    5,610
    with a bit of inspiration, and 8 extra boards of cherry, i decided to make the other kind of tostonero. i've set up cnc code to hollow out the dish, and engraving the words 'burro viejo' and 'tostonera' on the paddle part. i've laid out the design on the first board, which will serve as a template for the others, jointed one edge, and ripped them to width.
    Attached Thumbnails Attached Thumbnails 001 tostonera mk2 laid out.jpg   002 cherry boards for tostonera mk2.jpg   003 boards ripped to width.jpg
    benedictione omnes bene
    www.burroviejowoodworking.com
    13,468
    Very cool!
    BTW, you may have one, but if not, it looks like that sanding tube is getting pretty built up, these work great... http://www.amazon.com/POWERTEC-71002...dp/B00AJW0CY8/
    Dec 2008
    5,610
    thanks darren! i've got one that i've put to good use, just not after the last time... lol
    now i have to cut all the parts, then wait until i can get at the cnc, so that i can do the finishing cuts.
    Dec 2008
    5,610
    now that i can get back at all of my tools (nephew moved his furniture), i went to town on the tostoneras. first i cut all of the handle and flap parts. then rough cut around the lines of the handle. then sanded to the lines. after that, i rounded over the edges of the handle, drilled the hole, and rounded over the edges (won't do that on the others, learned a lesson there). then i got a pic of both parts together. i may do the cnc routing part tomorrow morning.
    Attached Thumbnails Attached Thumbnails 004 flaps and handles cut.jpg   005 handle rough cut.jpg   006 handle sanded to line.jpg   007 handle edges rounded over.jpg   008 handle hole cut.jpg
    Dec 2008
    5,610
    pulled the cnc out of its winter sleep today. set it up for cutting the dished out part with the 1/4" bit. it started out ok, but then it started some monkey business, trying to cut its way through the board, instead of only 1/4". oddly enough, i found that the collet nut was loose (thought it was tight, i know, famous last words). so i moved on to the engraving (much easier i hoped). it did the engraving ok, but it seemed to be light on the right hand side. could have been wrenched a tad when the other bit tried to get to china. i'll need to move the bottom text to the left a bit to center it a bit more.
    Attached Thumbnails Attached Thumbnails 011 ready for pocketing.jpg   012 pocketing results.jpg   013 engraving test.jpg
    Dec 2008
    5,610
    worked on the handle parts today. got them all cut, and sanded to the lines. then drilled the hanger holes, and rounded over the edges of the handles.
    Attached Thumbnails Attached Thumbnails 014 handle parts rough cut.jpg   015 handle parts sanded to line.jpg   016 hanger holes drilled.jpg   017 handle edges rounded over.jpg
    Thomasville, GA
    6,000
    Quote Originally Posted by Dan Noren View Post
    ... i found that the collet nut was loose (thought it was tight, i know, famous last words). so i moved on to the engraving (much easier i hoped). it did the engraving ok, but it seemed to be light on the right hand side. ...
    Something you need to check routinely is dust in the collet - needs to be blown out after each use. As a part of my routine, I run a quick flatten cut on my base board to be sure it's dead on with the bit before any etching carves.
    Bill Arnold
    Dec 2008
    5,610
    back at it again today. got the issues settled, and went on to make the indents in all of the parts. fixed the small problem with the engraving (moved the text over a bit). then did all of the engraving. all that is left is the sanding, fitting out the hinges, and the final oiling.
    Attached Thumbnails Attached Thumbnails 018 testing new setup.jpg   019 result of test.jpg   020 first good one from middle.jpg   021 all indents done.jpg   022 engraving sample.jpg
    12,264
    Now you cooking with gas Dan. 👍
    Dec 2008
    5,610
    finished them yesterday. got the sanding done, and put on the hinges. then gave them a good coat of mineral oil.
    Attached Thumbnails Attached Thumbnails 023 all hinges installed.jpg   024 all oiled.jpg   025 finished closeup.jpg
  1. tostonero project
    Last Post: 05-21-2016, 01:22 AM
  2. Need simple project idea for Boy Scout woodworking merit badge project
    By Jerry Ingraham in forum General Woodworking Q&A
    Last Post: 02-04-2012, 07:52 PM
  3. BF for a project
    By Eduard Nemirovsky in forum General Woodworking Q&A
    Last Post: 07-11-2008, 02:46 AM
  4. Done! Pics! better a small project than no project at all
    By Mark Kosmowski in forum Flatwork Project Showcase
    Last Post: 04-07-2008, 11:28 PM
  5. First Project
    By Gene Miller in forum Flatwork Project Showcase
    Last Post: 10-08-2007, 02:01 PM
