Made a three shelf cabinet years ago (25) with bottom doors. Bottom and middle are 12inch and top about 9. As you can see over the years the collection of cookbooks has far exceeded capacity. Bigger is this case is always better. Really you should look to your books or other items to be stored there. That should tell the height you need and add a little. Good luck
