glenn bradley
- SoCal
This will be soooo obvious to some of you. I'm in Southern California. I have an outer garage wall. Stucco outside, exposed studs inside. Most of the interior wall surface is insulated and drywalled. The exposed 7' x 12' area I would like to cover. Would you insulate and use drywall? Vapor barrier and T1-11 or like siding? Any suggestion will be superior to my most educated guess.
I will be putting French cleats on the wall and hanging pegboard panels, small cabinets or whatever as the shop evolves. I will also be installing some outlets to serve that area of the shop. This will also probably be the main area where my workbench stands; normally close enough to the wall to reach over and access the items hung on the pegboard.
I should mention that I plan to paint most of the shop interior a semi-gloss white unless you all have other advice on color and finish.
Thanks.
Thanks.
