Results 1 to 10 of 15
Thread: Old House Trim Question
    13,363
    So a friend is renovating an old house. They have some decorative trim on the house made out of old redwood.
    Apparently they need about 45 of these little round 'nubby' things. Is there a name for them?
    Would there be anywhere you could think of where they might be able to buy them? They look like they'd be a little bit of a pain to turn one by one.
    13,454
    I think the term you'll need to search on is "Onlay" maybe half sphere/ball.
    If they are painting again and don't mind using wood, perhaps using some split balls on a piece of sliced dowel or a puck that has been cut out by a hole saw...
    http://www.craftparts.com/balls-spli...c-277_278.html
    Edit: Might have luck with "Rosette" too.
    To a small child, the perfect granddad is unafraid of big dogs and fierce storms but absolutely terrified of the word boo. Robert Brault
    5,173
    Try house restoration sites. Often these things are made of Styrofoamed and stuccoed. Turning 45 of them would be a bit pricey. Or they could get a lathe and learn to turn, though spheres are not the easiest shape to make, let alone duplicate.
    Sites like this one: http://www.historichouseparts.com
    Good luck.
    Jan 2010
    Victoria BC
    87
    Make a mold
    https://www.smooth-on.com/
    Cast them out of resin or even cement
    13,363
    Ahh, That' looks perfect Brian.
    Toronto, Canada
    276
    Depends on how you do it ...
    Oct 2007
    Nova Scotia, 45N 64W
    1,247
    Seems like you could make them with a modified drill press rosette cutter. You'd have to grind a cutter to that hemispherical shape.
    Apr 2009
    Outside the beltway
    5,261
    I's turn short dowels , turn one cut it off and then the next. Or turn a longer stock and cut the knobs off with a Japanese saw. For furniture that's what I've done. Your not going to buy them anywhere.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    13,363
    Quote Originally Posted by Ed Thomas View Post
    That would knock them out in a hurry!
    4,699
    Quote Originally Posted by Dave Hawksford View Post
    You don't think that having them end grain like that would be a problem?
    I was thinking a screw chuck would be the fastest way to do it face grain, without Ed's fancy rig I think a quasi production turner could do them at around five minutes per so say $10-12 a pop including cutting the blanks and some not to fancy wood.
    Practically speaking I'm with Brians solution
  1. Wood Selection for Window Trim Question
    By Brent Dowell in forum General Woodworking Q&A
    Last Post: 05-04-2009, 10:10 PM
  2. Peeling paint on house trim
    By Dennis Thompson in forum Carpentry and Construction
    Last Post: 05-26-2008, 03:48 PM
  3. Bosch PR20EVSNK trim router kit question
    By Jack Lemley in forum New Tools
    Last Post: 01-15-2008, 05:56 AM
  4. Are there any house painters....in the house?
    By Greg Cook in forum Carpentry and Construction
    Last Post: 09-17-2007, 10:02 PM
  5. Aluminum Trim Question
    By Wes Bischel in forum Carpentry and Construction
    Last Post: 09-03-2007, 04:18 PM
