Results 1 to 2 of 2
Thread: Stacked Text on Layered Board
    Thomasville, GA
    5,998
    I wanted to make a stacked text plaque for some friends, but also wanted it to be a little different from most I see and have done.
    Here's what I ended up with:
    This shows the layers a bit better:
    To build up the board, I took a piece of cherry about 7/8" thick and re-sawed it to get a 1/10" veneer and a 1/2" base. After sanding the pieces smooth, I added a 1/10" thick piece of maple between the pieces of cherry. After sanding, the top layer of cherry and the maple came out at about 0.09". I glued the pieces together with Titebond II and clamped them overnight. In the meantime, I milled some wenge to 5/8" x 1/2" to make a frame with half-laps at each corner. Prior to starting the carve, I wiped some brown dye on the top layer of cherry to darken it. I adjusted the cut depth so the bits would cut through each layer by 0.01". Finish is a layer of waterborne sealer, two coats of waterborne clear gloss and a final coat of waterborne semi-gloss.
    Bill Arnold
    Dec 2008
    falcon heights, minnesota
    5,610
    way cool bill!
    benedictione omnes bene
    www.burroviejowoodworking.com
  1. Finished up stacked text and started a xmas gift
    By Darren Wright in forum Computer-Aided Equipment Project Showcase
    Last Post: 11-18-2015, 02:29 AM
  2. Stacked Text - Practice
    By Bill Arnold in forum Computer-Aided Equipment Project Showcase
    Last Post: 10-22-2015, 05:29 PM
  3. Another Stacked Text
    Last Post: 10-12-2015, 08:01 PM
  4. no text
    By Lanny Edgar in forum Carpentry and Construction
    Last Post: 01-11-2011, 05:06 AM
  5. Do you text?
    By John Pollman in forum Off Topic Discussion
    Last Post: 05-21-2009, 12:52 AM
