Results 1 to 4 of 4
Thread: Hydro powered pool lighting
    13,453
    One thing I've not liked about my pool is that we don't have any lighting for night swimming. I've looked at several options from the floating lights, to ones that hang over the sides, to the permanent installed versions. We'll need to replace the liner in a few years, so really didn't want to get into the permanent version until then, that and the cost of LED, low voltage options are coming down in price. Last year I tried the floating ones, but they were pretty weak and constantly were floating down into the skimmer.
    This year I found the style that screws into the return eyelet sockets. They have a small impeller built in that generates power for a ring of LED lights around the outer edge. The base has a 1 1/2" standard thread and the eyelets are adjustable to direct flow. The reviews were mixed on them, but decided to give them a shot. I ordered a two light set for $39.00
    http://www.poolsupplyworld.com/Mun-T...Light-BOGO.htm
    They stick out just a little more than the standard eyelet, but not bad.
Name:	2016-06-07 19.42.03.jpg
    The pics aren't quite a good representation, they are quite a bit brighter in person, and much better than no lights at all.
Name:	2016-06-07 21.25.45.jpg
ID:	96190 Click image for larger version.
Name:	2016-06-07 21.26.05.jpg
    Since they are self powered, they only run when the pump/filter is on, which we normally do turn on when swimming. Also, I did a check of the pressure gauge after a good back flush and rinse, then before and after installing the lights, the pressure was the same and flow seems to be the same.
    Overall, I'm impressed with them, hoping they last a while and even come out with improvements for future versions to get them even brighter.
    13,361
    Bright enough to let you know if there's a copperhead in there!
    13,453
    Knock on wood, I've only gotten one snake in there in 6 years, and it was a garden snake at least. We used to get some gigantic Wolf spiders in the skimmer. I ended up putting a rubber cork in the finger hole of the cover and not had issues with them since. Mostly get bull frogs and mice that go in for a drink. Mice usually drink themselves to death.
    Mar 2015
    Parker County, Texas
    1,502
    That's a neat idea. Not being one who has a pool, I have never heard of it. Sounds like a good idea to me. I didn't think any self respecting snake would get in a pool because of the treated water, but just goes to show what I know.
  1. Lighting a spraybooth
    By Dave Black in forum Finishing School
    Last Post: 07-29-2011, 03:07 PM
  2. Shop lighting
    By Ken Schweim in forum General Woodworking Q&A
    Last Post: 09-10-2010, 07:29 PM
  3. I actually have lighting!!
    By Matt Hutchinson in forum Shop Tours
    Last Post: 07-18-2009, 02:36 AM
  4. Shop Lighting
    By Bruce Moffitt in forum Shop Tours
    Last Post: 04-19-2009, 08:15 PM
  5. Lighting from Lowes...
    By Greg Cook in forum Carpentry and Construction
    Last Post: 08-02-2007, 09:49 AM
