Results 1 to 3 of 3
Thread: Some CNC program questions
    5,167
    I am probably overthinking a situation here. I have not yet purchased V-Carve Pro and I wonder if I should even though my machine is a long way from operational.
    Here is the deal. I am traveling a very winding path to get a executable file for the Laser to use. Its program requires the import of a dxf file with measurements in mm. I have been using SketchUp for original drawings. Now I want to use a photo to create a cooling grill for the electronics bay of the cabinet. I have imported it into SketchUp as a .jpg. Resized it to fit the opening. Drew a mounting frame boarder around it.
    Now I need a vectorized file to export as a dxf.
    Can I take my 'drawing' into V-Carve Pro and find the edges of the pattern, clean up the polylines and export it as a dxf to import into the Laser cut file?
    What else will I need to know?
    Thomasville, GA
    5,992
    Yes, VCP will export as a DXF, as well as EPS, AI and SVG.
    VCP can also import a SketchUp file directly. Then, you don't need to have VCP "fit vectors to bit map".
    Edit: Another approach is to take SU out of the loop. Import the jpg to VCP, fit vectors to it, clean them up and resize to whatever you need.
    Bill Arnold
    5,167
    Just what I needed to hear, Bill. Thanks so much. Since I work on a MacBook but have acquired a PC for my machine, I will set up the PC, download the free trial version and get to learning!
  1. New Excercise Program
    Last Post: 07-28-2010, 06:16 AM
  2. Plywood Cut list program for a Mac?
    By Mark Rios in forum General Woodworking Q&A
    Last Post: 10-10-2009, 01:58 AM
  3. Decent Graphics Program for Mac
    Last Post: 09-17-2009, 05:39 PM
  4. Anyone program in Perl?
    By Jeff Horton in forum Off Topic Discussion
    Last Post: 02-10-2009, 07:57 PM
  5. Festool giveaway program.
    By Steve Ash in forum Off Topic Discussion
    Last Post: 04-02-2007, 12:44 AM
