Results 1 to 10 of 10
Thread: Grille for Edison Phonograph
    Thomasville, GA
    5,991
    LOML recently was given an Edison LU 37 Diamond Disc Phonograph built around 1922. Some of her cousins had it and wanted to find a good home for it. Aside from extensive cleanup, it had all parts but the grille.
    I checked around online and found some photos of the same type phonograph to see the design of the grille.
    Next, I went to work in VCarve Pro to do a layout. The only measurements I had were the height and width of the opening - 10.25" by 14.75". So, I did some calculations, tested some dimensions and finally got a suitable design. A combination of circles, half-circles, arcs and straights got it started, then I had to do a lot of node editing to setup the carve properly.
ID:	96350Click image for larger version.
    I set up my cnc to do most of the cuts with a 1/8" end mill running at 70ipm and 1/16"doc. I set up a final pass using a 1/16" end mill to get into the small notches and clean up the previous carving.
ID:	96352Click image for larger version.
    OK, so I didn't get photographs of the finish steps, but you wouldn't want to watch paint dry anyway! My first step was wiping on some brown mahogany stain. To darken the grille more, I sprayed shellac with a few drops of TT Dark Walnut dye in it. Then, I sanded that back a little to expose the stain and give the grille a distressed appearance.
    Here's a before and after look at the phonograph.
ID:	96354Click image for larger version.
    Momma's happy, so I guess all is well!
    Bill Arnold
    Oliver Springs, TN
    1,726
    That my friend is a sweet job! I've played with VCarve a little, it's one of those things I just need to stick with so I can figure it out.
    13,356
    Oh that is awesome!
    How does it sound? Do you have any records for it?
    5,167
    Looks terrific! Also very inspiring for me to get my act together.
    13,433
    Well done Bill, looks like it was the original.
    East Freeetown, Massachusetts
    3,017
    Just LOVE the notion of using a 2016 CNC technology to do restoration on a 1922 piece.
    What a GREAT job.
    Thomasville, GA
    5,991
    Thanks to all of you for your comments!
    The sound from these machines is amazing, considering the technology. No electronics, of course, but the volume will fill the house! The larger machines with a 12" horn also have a ball that serves as a volume control so you can reduce the volume as desired. This smaller unit has a 10" horn and no volume ball. We have a total of 65 diamond disc records.
    Quote Originally Posted by Leo Voisine View Post
    Yep! The original grilles were most likely made using a treadle type scroll saw.
    I forgot to mention in my original post that I used my pin nailer to attach the mahogany board to the cnc waste board. That way I didn't have to use tabs to hold all the pieces together.
    Bill Arnold
    May 2009
    Poway, CA, near San Diego
    174
    Very nice job.
    In case you don't know, Victrola needles should be used only once. They will damage the records if re-used.
    http://www.victor-victrola.com/Needles.htm
    Bob
    Thomasville, GA
    5,991
    Quote Originally Posted by Bob Meyer View Post
    Very nice job.
    This isn't a Victrola. It's an Edison Diamond Disc Phonograph that uses a diamond stylus.
    https://en.wikipedia.org/wiki/Edison_Disc_Record
    Bill Arnold
    May 2009
    174
    Ah ha.
  1. Edison Pens
    By Pete Simmons in forum Lathe Project Showcase
    Last Post: 05-02-2008, 01:46 PM
  2. Craftsman: Edison Idea?
    By Travis Johnson in forum New Tools
    Last Post: 03-21-2008, 06:52 PM
  3. SKETCHUP Tut--Grille
    Last Post: 11-26-2006, 06:06 PM
