Results 1 to 9 of 9
Thread: Deck plans?
    13,357
    Deck plans?
    Does anyone have a good source for plans or guidelines on building a deck?
    I need to build a freestanding deck that be next the new pool I put in.
    The pool is next to a hill side, so it will be going from the pool right up to on ground.
    In the picture below, I'll be putting the deck in on the side closest to the picture taker, with stairs going down off to the right, and a enclosure of some kind to protect the pump and filter.
    4,698
    What will the dimensions be? That is how tall will it be (at the pool side) and how far out from and around the pool will you be going?
    Can you get bob up into all the areas where you'll want posts to dig some holes for the footers?
    Looking forward to seeing Chuck's advice..
    13,357
    Footers would be difficult no matter what.
    I can probably sink a couple of holes here and there, but not sure I really want to make it quite that permanent.
    We don't really have the issue with frost heaves, as it never really gets cold enough long enough to worry about.
    The pool is 15x26, so I'm thinking the deck will just go around halfway, so 20-26' long, and I'd like it to extend up on the hill side , probably 10'-15' wide.
    The pool is 54" high, so that's the height on one end, and the height on the hill side would whatever it takes to be flat.
    4,698
    Basic guidelines:
    http://www.awc.org/codes-standards/publications/dca6
    Specifically the deck building guide
    http://www.awc.org/pdf/codes-standar...Guide-1405.pdf
    And the inspection checklist (for a short list of things that people usually do wrong):
    http://nadra.org/Deck_Evaluation_Form.pdf
    I think you'll want to set the footers in some, otherwise its likely to go all skewy regardless of bracing underneath. This suggests 12" as a minimum depth, perhaps with your rock problems digging a smidge deeper and compacting in some 3/4 minus crush would make it easier to level the piers.
    http://www.finehomebuilding.com/2012...lding-mistakes
    13,357
    12" footers would probably not be that big of an issue. I could do that easily enough.
    13,438
    I don't know how far around the pool you want to go, but I'd probably do 4 main beams on posts with cross bracing between them (if you're just putting posts on pads), then run the joist between and shape your header joists around the pool as shown, then run the decking towards the pool just under the top cap. If that make sense.
Name:	2016-07-05 10.08.55.jpg
    Someone else may have a better solution though.
    13,357
    Hey, Thanks Darren. That looks like what I should probably do!
    Now to put together a shopping list.
    Dec 2009
    Hillsborough, NC
    58
    One possible "less permanent" option that meets code here in NC is a hole with two layers of solid 4x8x16 cinder blocks, two blocks in each layer, and the top layer at 90 degrees to the bottom layer. Center the post on the pad (a CMS is really helpful for getting the posts plumb) and backfill the hole with dirt to keep the post from shifting. If I remember right, 4" of backfill was sufficient for my inspector, so the holes were only 12" deep and no need to pour concrete.
    --dave
    --dave
    17,471
    up here you need to use 4x6 not 4x4 they dont have ground contack treatment on 4x4's
  1. Buying plans or using magazine plans.......my view
    By Rob Keeble in forum Designs, Plans and Sketches
    Last Post: 01-15-2013, 02:41 PM
  2. Deck Refinish
    Last Post: 05-05-2012, 09:55 PM
  3. Outdoor furniture -plans, no plans, leftover wood, scraps
    Last Post: 06-13-2008, 11:17 PM
  4. Deck piers
    By Mike Gabbay in forum Carpentry and Construction
    Last Post: 05-28-2008, 01:57 PM
  5. My Deck Project
    By Sean Wright in forum Carpentry and Construction
    Last Post: 03-29-2007, 03:47 AM
